Go to Post The real world does not go together like an Erector set. FIRST robots should not either. - dlavery [more]
Unread 13-02-2008, 18:36
govvijay govvijay is offline
FRC #0540
govvijay is an unknown quantity at this point
Printing Analog Input with Kevin's new code
We are trying to print analog values from our autonomous switch, but we are only getting 0 values. I was just wondering how do you print analog inputs using Kevin's new code.
Thanks,
Vijay G.
Unread 13-02-2008, 18:45
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Printing Analog Input with Kevin's new code
It should be normal, something like:
        for (k = 1; k <= NUM_ADC_CHANNELS; k++) {
            printf("ADC %d: %d\r\n", k, Get_ADC_Result(k));
If you want to get fancy. Make sure the number of ADC channels is set correctly in adc.h. This looks more like an electrical problem though. You may want to check with an oscilloscope that you are actually getting values from the ADC.
Unread 13-02-2008, 21:21
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Get_ADC_Result() returns an unsigned int, so you'll want to use %u in your printf() format string instead of %d.
-Kevin
Kevin Watson
http://kevin.org
Problem with Kevin's 2008 code jc4p Programming 4 06-02-2008 17:48
Errors compiling Kevin's new code (pragmas) Bryan Herbst Programming 11 31-01-2008 12:50
Problem with Kevin's code Tottanka Programming 5 04-11-2007 13:32
Problems with Kevin's 2007 default code bruss6 Programming 8 19-01-2007 15:42
What are with the Ls in Kevin's code??!!! HELP!!! RbtGal1351 Programming 2 18-02-2005 16:57
