Go to Post Please share your opinion and post whatever you want, I wouldn’t mind. Because I may be wrong. - Arefin Bari [more]
Unread 13-02-2008, 20:13
Guarana Guarana is offline
FRC #1706
Guarana is an unknown quantity at this point
New Code - No Movement
So I was using the Default Code from IFI and it worked perfect. I needed a gyro programmed, so I was adding kevin's gyro and adc files. After having some trouble, I found his code that was completely implemented already. I downloaded that, transfered the mecanum programming to the ifi_code.c file in Default_Routine(). The problem is, the wheels will not spin at all. The victors do not get any value sent to them. I commented out all the mecanum code and just assigned the pwm's to the value '1' and still nothing spins. I tried my old code and it will spin, kevin's code just will not work.
I am using MPLAB IDE 8.0 and C18 3.1 if that makes a difference. Help.
Thanks
Unread 13-02-2008, 20:17
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: New Code - No Movement
Try adding your code to void teleop (void) in teleop.c. That should fix the problem. If not, post the code.
Movement Hunter1539 Rules/Strategy 4 09-01-2008 22:06
Where to insert new code? katkana Programming 5 19-02-2005 13:47
New Default Code nukem Programming 2 12-01-2005 17:45
Strange IR sensor movement with default tracker code wun Programming 5 19-03-2004 10:51
New Code Simulator Available? authgeek1218 Programming 1 03-12-2003 13:18
