So I was programming yesterday night and started downloading some code, and some genius member of our team decided to trip over the program cable, yanking it out. After this, the robot controller won't get out of program mode, and I can't get it to take any code... Can I fix it somehow, because time is of the essence...
Re: HELP! Program cable disconnected...
you could try downloading the master rc code
Yeah I think I tried that... It won't let me download anything!
I've had that happen a few times. I press the reset button and then hold the program button for a second (the light won't change). I'm then able to re-download the program.
Feeewww! Thanks, hopefully that'll work...
There's some combination of buttons you can press that will do some larger reset. It's hidden on the IFI website. Also try downloading the default code.
#7
Hold down reset and programming buttons, release reset and hold down programming button for another 10 seconds. It goes into a diagnostic mode from which you can reprogram.
HTH |
| Danger in Disconnected IR Receiver | Mark McLeod | Programming | 7 | 06-02-2008 07:56 |
| 2007 tether and program cable question | Japper | Control System | 11 | 08-05-2007 20:55 |
| Reliable way to detect disconnected controller | heydowns | Control System | 4 | 13-02-2007 08:30 |
| Program Port Y-cable | CyberWolf_22 | Control System | 5 | 01-02-2005 21:21 |
| Program Port Y-cable | CyberWolf_22 | Electrical | 5 | 01-02-2005 21:21 |
