Go to Post just want a picutre of my "CD idols" - Ryan Albright [more]
Unread 13-02-2008, 20:36
Somekid1234 Somekid1234 is offline
Somekid1234 is an unknown quantity at this point
Exclamation HELP! Program cable disconnected...
So I was programming yesterday night and started downloading some code, and some genius member of our team decided to trip over the program cable, yanking it out. After this, the robot controller won't get out of program mode, and I can't get it to take any code... Can I fix it somehow, because time is of the essence...
Unread 13-02-2008, 20:37
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: HELP! Program cable disconnected...
you could try downloading the master rc code
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 13-02-2008, 20:39
Yeah I think I tried that... It won't let me download anything!
I've had that happen a few times. I press the reset button and then hold the program button for a second (the light won't change). I'm then able to re-download the program.
Unread 13-02-2008, 20:40
Feeewww! Thanks, hopefully that'll work...
Unread 13-02-2008, 21:31
Kelly Kelly is offline
FRC #1418
Kelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud ofKelly has much to be proud of
There's some combination of buttons you can press that will do some larger reset. It's hidden on the IFI website. Also try downloading the default code.
Unread 13-02-2008, 22:07
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Hold down reset and programming buttons, release reset and hold down programming button for another 10 seconds. It goes into a diagnostic mode from which you can reprogram.
HTH
Danger in Disconnected IR Receiver Mark McLeod Programming 7 06-02-2008 07:56
2007 tether and program cable question Japper Control System 11 08-05-2007 20:55
Reliable way to detect disconnected controller heydowns Control System 4 13-02-2007 08:30
Program Port Y-cable CyberWolf_22 Control System 5 01-02-2005 21:21
Program Port Y-cable CyberWolf_22 Electrical 5 01-02-2005 21:21
