Go to Post Come on how can you not be excited about IRI! - richardp [more]
Unread 13-02-2008, 20:32
Team2441 Team2441 is offline
AKA: Danielle
FRC #2441 (Team 2441)
Team2441 is an unknown quantity at this point
IRI Bord question
Our team is thinking of putting our IRI board under a plexi glass cover that is protecting the electronics. Will it still be able to receive a signal under the plexi glass?
Unread 13-02-2008, 20:35
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: IRI Bord question
If It's clear I'm pretty sure it will. One way to find out is to try it!
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-02-2008, 20:41
AKA: Danielle
Thank you very much its better to be safe then sorry
Unread 13-02-2008, 20:50
program1's Avatar
program1 program1 is offline
AKA: RJ
FRC #2441
program1 will become famous soon enough
ok i don't want to make a new thread for a question about the IR also,
where is the best place to put the IR board?
ok, who ate my hot pocket?
Unread 13-02-2008, 20:53
Imaginary Friend
AKA: Kevin Li
Team Role: Student
That depends on your robot design... You should put it somewhere visible so you can use the remote and also somewhere safe from impact. We're probably going to mount it on a servo and stick it in the front with some polycarb around it to protect it.
Kevin Li
596 - Sciclones
ASAP IRI Question--!! litchi_chan Off-Season Events 2 01-08-2007 21:04
IRI Travel Arragements (Airport -> IRI -> Airport) BandChick Off-Season Events 14 18-07-2007 15:30
IRI Molten General Forum 7 02-04-2007 16:45
IRI Travel arrangements (airport to IRI & IRI to airport) Elgin Clock Off-Season Events 25 19-07-2006 11:04
FF IRI 2.0 Ian Curtis Fantasy FIRST 80 24-07-2005 20:11
