Go to Post Kit wheel? Someone probably has them. N-tooth IFI sprocket? You might get lucky. Part Made By A Local Company When You're Competing 800 Miles Away? Bring three. - Billfred [more]
Unread 13-02-2008, 21:14
Chaos204's Avatar
Chaos204 Chaos204 is offline
AKA: Jordan
FRC #0204 (Eastern Robotic Vikings)
Chaos204 is on a distinguished road
Send a message via AIM to Chaos204
Keyang Accident
OK so we had an accident today and i am trying to assess the damages. we have both keyang motors driving an arm with a lot of torque. we are using gas springs to levy the load on the motors, but as we were installing today the arm fell. the arm nearly crushed the electronics, but a chair broke the arm's fall. (Nobody got hurt, they just wet their pants)
As it fell i heard clicking. Not knowing too much about the keyang it scares me. It seems to work OK. I cannot turn the gear with my hand with no power and with power it spins. when the motor is moving a load i hear the same clicking when it stalls.
Any Idea whether it is broken?
2005 PARC FINALIST
with 84 and 176
E. R. V. is on its way
Unread 13-02-2008, 21:18
Re: Keyang Accident
Is the clicking coming from the motor or the breaker panels?
Unread 13-02-2008, 21:21
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
Re: Keyang Accident
sounds like you may have broken part of the worm gear, I just tore one of ours apart, because like you we had/are having problems with the keyang motors. Inside there are only these tiny nylon worm gears, they are very susceptable to binding or crushing.... We stalled one of ours, drew almost 22 amps, now it is junk........ :-(
TEAM 549
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Keyang Accident
Were the Keyangs being back driven as the arm fell?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 13-02-2008, 21:28
Chaos204's Avatar
AKA: Jordan
Re: Keyang Accident
Wow, had not thought of it coming form the breaker could it possibly be reseting in such a fast interval. If i was describing it i would say it was the motor, it sounded like a clutch or something. Does it have something protecting it form breaking itself like a clutch? It reminded me of a toy i used to have called Rrokenbok when you pushed past the motor with your hand it makes a clicking noise similar to this sound.
hard to tell it all happened so fast. I think we started to lower it slowly but th guy steadying the arm got surprised and drooped it. I assume when it fell the operator stopped pulling the joy stick.
2005 PARC FINALIST
with 84 and 176
Unread 14-02-2008, 01:03
Cptn Patches537 Cptn Patches537 is offline
AKA: Eric Larson
FRC #0537 (Charger Robotics)
Cptn Patches537 is infamous around these partsCptn Patches537 is infamous around these parts
Send a message via AIM to Cptn Patches537
Re: Keyang Accident
What is connecting the motor to the arm? You may be so preoccupied and worried that your belt might be skipping without you noticing it... I know this is unlikely but we used a belt last year with dual keyangs and it worked very nicely. we just had to design some improv tensioners to keep the belt from skipping.
2007: -Wisconsin Regional Chapions
-Regional Engineering Inspiration
-Regional Rockwell Innovation in Control Award
2006: -St. Louis Regional Champions
-K,P+B Award at St. Louis and Wisconsin
2005: -Midwest Regional Champions
2004: -St. Louis Regional Champions
Unread 14-02-2008, 02:09
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Re: Keyang Accident
I believe the worm gear inside the keyang motor is metal and the spur gear is nylon. We stripped two or three of the teeth on the nylon spur gear last year during some demos after our robot had been through one regional and championship. We ended up having to get a replacement from another team (special thanks to 499!) so that we would still have a working arm for future demos.
If you guys have the same problem we did, and that's what it sounds like, your arm would still work because one motor can support your arm when the spur gear in the other motor has its stripped teeth next to the worm gear. But, you might want to try and replace it just so that you always have both motors supporting the load. Hopefully a team in your area has a spare they're not using!
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 14-02-2008, 10:10
Chaos204's Avatar
AKA: Jordan
Re: Keyang Accident
Any thoughts on how i might test to see if it is broken?
2005 PARC FINALIST
with 84 and 176
Unread 14-02-2008, 10:21
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Keyang Accident
Two clues: 1. You heard clicking when the arm fell (I assume the motor was trying to hold up the weight of the arm). 2. You hear the same clicking when you run the arm motor to "stall".
It sounds to me like you have partly damaged the spur gear teeth inside the motor, and it can take only part of the load it is designed for, then starts to slip, the clicking sound is the gears skipping teeth as the worm gear turns and the spur gear just stays still.
Sounds like you need a new motor, and probably a few spares as well, or figure out how to make sure the load on the motor is never high enough to damage it again (which is hard to do!)
Unread 14-02-2008, 10:25
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Keyang Accident
Unfortunately neither the Keyang nor the Van Door motor seem to have the torque we've come to expect. Even the RS-540 with the right gearbox has more torque and is less susceptible to breaking.
You definitely are stripping a gear when it's under load. Either a tooth is cracked or breaking, or the plastic gears are flexing/grinding and are about to break.
GitHub
Accident? Betty_Krocker General Forum 11 10-01-2008 22:15
Gmail Accident Yan Wang Chit-Chat 18 21-02-2005 22:14
NASA JPL Accident Mark Pettit General Forum 9 08-12-2004 17:05
funniest accident while building bot johnscans Chit-Chat 17 11-01-2003 18:56
