Go to Post I do know a lot of teams need to be saved from themselves. - Karthik [more]
Unread 13-02-2008, 22:59
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
Mecanum needs a flat floor
We were driving our recently assembled mecanum robot around, and have noticed that even a slightly uneven floor can result in problems maneuvering (going straight tends to work well everywhere). Even with the large number of mecanum drives this year I haven't seen anyone voice any concerns about this. Do you guys think that this will be a problem?
Unread 13-02-2008, 23:06
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Mecanum needs a flat floor
There have been many threads about mecanum drives and their need to have all four wheels contacting the ground.
They have basically been discussions about the importance of a suspension to ensure that imperfections in the chassis or the floor don't screw up the driving.
Just a small bit of movement with a suspension should be good considering how the carpet flattens a bit under the robot.
We used a mecanum drive last year with rubber dampers acting as a sort of "suspension" and had no problems. The wheels moved about 1/8th of an inch or less.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
The Megan 2207's Avatar
The Megan 2207 The Megan 2207 is offline
FRC #2207 (Prime 329)
The Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really niceThe Megan 2207 is just really nice
While testing our mecanum wheels, we decided to see if they can handle bumps. One of our team members threw his shoes in front of the robot. Apparently, our robot can drive over shoes. The same team member then decided to see if the robot can drive over him. It couldn't.
Anyway, I don't think an uneven field will be a problem (for driving, anyway... line sensors are another story).
Unread 13-02-2008, 23:16
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Unfortunatly, as you have discovered, mecanum and holonomic drives need a level surface to function properly. Some kind of suspension is usually used. I'm not sure how your's is set up, so this probably won't work, but this is the simplest way I could come up with:
have pillow blocks holding up your shafts. Put them offset from the chassis by about an inch, and have the screws used to offset them on springs. They will be normally compressed, and uncompress when weight is taken off of them
Unread 15-02-2008, 23:52
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
you do not need an flat even floor for mecanum wheels, yes a flat floor is ideal but the bumps in the field will be no problem for the mecanum wheels
I know that the wheels are slightly different (at least from our robot) and are alot bigger but check out http://www.airtrax.com/video/Obstacle_navigation.wmv that video from airtrax
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 16-02-2008, 00:31
llama llama is offline
AKA: Michael Goelz
FRC #2077 (Kettle Moraine Robotics/Laser Robotics)
llama is an unknown quantity at this point
Send a message via AIM to llama
in the video they even mention that the wheels are cushioned so they do in fact need four points of contact at all times...
Unread 16-02-2008, 00:45
No Stolte No
AKA: Chris
ya and they are slightly different, but we have had our robot run over shoes(yes it was my shoe) and other items and it has had no problem going over and we have the mecanum wheels from andymark plus all types of wheels idealy want to have all wheels touch the ground
finish line flat? nekng Rules/Strategy 22 22-01-2008 23:41
Flat Scren Displays rcubes85 General Forum 13 20-08-2006 09:44
flat sheet layout of helix? Bob Holmstrom Inventor 12 09-02-2006 07:21
The World is Flat Beth Sweet Chit-Chat 0 23-10-2005 22:16
