Go to Post Ah AndyMark and your $2 a piece pool noodles - mlantry [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 22:11
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Joysticks.....Again. check it out, Joe.
Posted by S. Krussell.
Coach on team #349, Robahamas, from International Academy and Ford Motor Co..
Posted on 2/29/2000 3:52 PM MST
Hi People,
We called Eric Rasmussen, the tech person at FIRST today. He told us that we cannot use any joysticks except the type provided in the kit, the 'Flight Sticks'. Since the conversation indicated otherwise last week, i thought that you all should know,so as not to have a problem at competition. So, to repeat, we cannot change the type of joystick. It's too bad, because we're not too happy with these.
#0047 (ChiefDelphi)
Interesting response...
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Posted on 2/29/2000 6:04 PM MST
In Reply to: Joysticks.....Again. check it out, Joe. posted by S. Krussell on 2/29/2000 3:52 PM MST:
This is a very interesting response from FIRST.
How then are we to determine what is an unlimited 'material' and what is forbidden?
100Kohm pots are allowed as long as they are linear taper and wired as indicated.
Switches of any kind are allowed as long as they are wired as indicated.
Wire: it too is allowed.
Plastic: Allowed
Put them all together: Not allowed
What if a team used a joystick only for its switches?
Let's say that FIRST says, No, this is not allowed. Then what about a larger industrial palm switch from McMaster say? Is this allowed as a switch or disallowed as a joystick?
How are we to decide where a legal linear tape pot or a standard switch in an unlimited material ends and an illegal component begins?
How is this going to be determined?
Joe J.
#0047 (ChiefDelphi)
my interpretation
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/29/2000 7:01 PM MST
In Reply to: Interesting response... posted by Joe Johnson on 2/29/2000 6:04 PM MST:
: This is a very interesting response from FIRST.
: How then are we to determine what is an unlimited 'material' and what is forbidden?
: 100Kohm pots are allowed as long as they are linear taper and wired as indicated.
: Switches of any kind are allowed as long as they are wired as indicated.
: Wire: it too is allowed.
: Plastic: Allowed
: Put them all together: Not allowed
: What if a team used a joystick only for its switches?
: Let's say that FIRST says, No, this is not allowed. Then what about a larger industrial palm switch from McMaster say? Is this allowed as a switch or disallowed as a joystick?
: How are we to decide where a legal linear tape pot or a standard switch in an unlimited material ends and an illegal component begins?
: How is this going to be determined?
: Joe J.
Here's how i'd interpret this...
homemade = ok
off-the-shelf(due to possible incompatibilites) = not ok
Nate
#0047 (ChiefDelphi)
same here
Posted by Justin Stiltner.
Student on team #388, Epsilon, from Grundy High School and NASA, American Electric Power, Town of Grundy.
Posted on 2/29/2000 7:06 PM MST
I know what you mean Joe I wish I could use a joystick from a R/c airplane radio I like it better because it is shorter and more suted to our robots handeling
I always end up holding the joy stick with my thumb and index finger below the grip ( force of habbit)
Justin Stiltner
[IMG] code is Off
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
The future ... thanks Joe J. archiver 1999 0 23-06-2002 23:03
Raul & Joe battle for second... archiver 2001 6 23-06-2002 22:45
WDW Park Hopper Passes-How to check joe_balint General Forum 19 21-05-2002 16:28
