Go to Post FIRST will work with you if you work with them. - R.C. [more]
Unread 17-01-2008, 14:00
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Bumpy Ride with AM's 8" Mecanum wheels?
My team has assembled the 8" mecanum wheels from AM and we are getting a really bumpy ride...
the robot jumps all over the place and nearly shakes itself to pieces.
this happens both in slow speeds and in hugh speeds.
is this a common problem with the 8" wheels?
or maybe we did something wrong?
do the 6" mecanums from AM solve this problem?
thanks!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 17-01-2008, 14:33
Re: Bumpy Ride with AM's 8" Mecanum wheels?
Before you get too worried about it skittering around, try putting more weight on the wheels. I think you'll also find that feedback-based control of wheel speed can smooth things out a lot.
Unread 17-01-2008, 14:44
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
I thought that the larger diameter wheels, that something has the smoother the ride should be.
Design. Build. Dew.
Unread 17-01-2008, 14:46
Definitely add weight. A light mecanum (around 50 pounds) bounces a bit, but bring it up to 120 and it won't bounce nearly as much.
Unread 17-01-2008, 14:58
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Joe: from Royal Jesters, want to chime in on this discussion??
The problem is iinherent with a wheel of this design. The mathematical formula that the individual segments of the wheels, in effect, the optimal shape of the rollers is patented. The optimal shape is one that keeps a portion of the rollers in contact with the carpet at all times. Team 357 can give you the better low down on wheel/roller shape than I.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 17-01-2008, 15:18
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Thanks for the swift replies!
We added about 100 pounds of bricks to the robot, which helped, but did not alleviate the problem altogether.
i'll try to get a video up so you can see for yourself how bouncy it is.
Rosiebotboss, do you think/know if the new 6" am which have a smoother shape solve this problem?
from my geometry class I seem to remember that the intersection between the relevant shapes in this design should be an ellipsoid but I'm probably mistaken because it doesn't seem like someone could patent an ellipsoid
-Leav
-Paraphrasing JFK
Unread 17-01-2008, 15:25
AKA: Dana P. Henry
go to www.team357.com and http://www.airtrax.com/ and look for the reference to their MIT/Inventeam project.
Airtrax is the "world leader in omni directional technology." Check it out.......their whell chair is prett neat and patented and going onto production (the last time I talked to the team leadership)
Unread 17-01-2008, 15:38
in between teams
AKA: Luke Van Oort
The 8" AM mecanum approximates the ideal roller shape with a few rubber cylinders; on the other hand, the 6" actually has a curved roller. Although I have no first-hand experience to back it up, I think the 6" will give you a smoother ride. I don't think the difference is worth another $300 though... just use locking nuts with the nylon inserts on your robot and tighten them and your electrical connections after every match and you should be fine.
Team 1219: 2009 - Mentor
Unread 17-01-2008, 15:42
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
There IS one gotcha....
The wheels are normally bumpy because the shift of ground contact from one roller to the next is not always smooth. As long as the rollers are at a 45 degree angle then everything should be good except....
There is only one wheel configuration that will work and give you all functions.
( I know they refer to them as "Right" and "Left" but that's not necessarily the side they go on.)
looking down FROM on TOP...look at the top rollers and then look at the roller bolts. They should make an "X" pattern like this:
If you don't have this configuration, you can drive forward, backwards, left and right BUT you'll have a terrible time trying to rotate and that will be really bouncy.
My two cents
Steve
Unread 17-01-2008, 18:20
bobdahaxor's Avatar
bobdahaxor bobdahaxor is offline
Making the impossibe... possible
AKA: Andrew Lane
FRC #1727 (Dulaney robotics)
bobdahaxor is an unknown quantity at this point
you probably drove this around on tile surfaces. The carpet makes a HUGE difference! Get some carpet and the bricks and it should be fine. The wheels will bounce a bit naturally but should not be that bad. My team used 3 inch omni's our 1st year and it bounced a bit, but was fine.
Unread 13-02-2008, 22:52
Lesman's Avatar
Lesman Lesman is offline
FRC #1014 (Bad Robot)
Lesman will become famous soon enough
We've put together out 8" mecanum bot also, and it vibrates a lot too. We are considering putting electronics and such on a 3/8" sorbothane pads to absorb shock. Do you guys think this would help?
Unread 14-02-2008, 01:06
monty1540's Avatar
monty1540 monty1540 is offline
College Student Mentor
AKA: Eric
FRC #1540 (The Flaming Chickens)
monty1540 is an unknown quantity at this point
Send a message via Yahoo to monty1540
We used the 8" A.M. mecanums last year, it was definitely a bumpy ride even with a 110 lb. robot. This year we're using the 6" A.M. mecanums and the ride quality is significantly better.
That said, we simply checked the tightness of the structural fasteners between every match last year and had no problems due to the vibration [not many problems at all - but that's both luck, and a different thread topic]. Use loctite and nylock nuts where you can, and check the other bolts frequently and you should be able to cope just fine with the vibration.
Another thing we noticed was that after hard use, the 8" wheels wore-in some, i.e. the hard corners on the rollers wore off to a rounder profile. It isn't perfect (still vibrates significantly) but they do wear-in after a while.
-Eric
Current WPI Student and college mentor to 1540
1540:
2008 Portland Regional Winner
2008 Portland Regional Engineering Inspiration Award
2007 Pacific Northwest Regional Finalist
2007 Pacific Northwest Reigonal Chariman's Award
Unread 14-02-2008, 01:16
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
When designing any mechanum drive it is important to account for vibrations. Our team used the 6" wheels on an offseason robot and have to give the robot a suspension system for proper driving. Short of that there is really not too much that can be done other than tightening down your bolts and hoping for the best.
Assistance with Mecanum Wheels CollmandosGrl General Forum 8 14-01-2008 17:42
Mecanum wheels akash155 General Forum 12 20-02-2007 22:15
Mecanum Wheels Calvin_1631 Motors 7 09-02-2007 13:29
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
Teams With Mecanum Wheels Foss@Team176 Technical Discussion 15 06-10-2005 09:38
