Go to Post After all, bitterness takes all the fun out of wiring. - Venkatesh [more]
Unread 13-02-2008, 20:11
emmell's Avatar
emmell emmell is offline
Murphy was an Optimist!
AKA: Mannie Lowe
no team (They're all my teams)
emmell is just really niceemmell is just really niceemmell is just really niceemmell is just really niceemmell is just really nice
Mounting GTS - how close is close?
Okay, based on trying to mount our GTS next to Andy Mark transmission gears, it appears that our GTS has to be touching the gear in order to count accurately.
Yes, we have the fixed GTS with the right parts and it is wired correctly because we are getting readings. We're just worried that we will chew our sensor alive.
The range (according to specs) is from 0.5mm to 3.0mm to get a reading and yet we can't get a reading unless the sensor is close to 0.1mm away from the gear.
All help is appreciated.
Mannie Lowe
Mannie Lowe
FIRST Program Manager - Center for Mathematics and Science Education - University of Mississippi
Mississippi FIRST Tech Challenge Affiliate Partner
Unread 13-02-2008, 22:24
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Mounting GTS - how close is close?
Are you talking about the kit GTS? Have you tried aiming a different face of the sensor at the gear? Can you post a picture of your setup?
Unread 14-02-2008, 01:24
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Using the kit GTS we have gotten readings from about 1.5mm away. have you tried taking the sensor out of the gear box and spinning a gear on a shaft at variable distances from the magnetic reader and seeing what you get?
Unread 14-02-2008, 08:12
Mannie,
The GTS is sensitive in only one plane. You might want to reorient to gain the max output. The data sheet is here...
http://www.allegromicro.com/en/Produ.../0642/0642.pdf
Page 5 shows the corrrect orientation to the package for gear tooth reading.
Unread 14-02-2008, 10:39
Tom Bishop's Avatar
Tom Bishop Tom Bishop is offline
FRC #0832 (Oscar)
Tom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant future
Aha, Al, so you would mount it sort of like this?:
l
l pcb
l
l
SSS sensor
GGGGG gear
we had it in a different orientation...OOOPPPPPPPs
Unread 14-02-2008, 10:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
that's right...you might be able to see it in this picture, too.
Unread 14-02-2008, 11:56
We don't use one so it has been a long time since I played with it. But I think you will find it works if you change the orientation. Passing a screwdriver tip past the device ought to give an output as well.
Unread 15-02-2008, 00:35
emmell's Avatar
AKA: Mannie Lowe
To everyone that answered our question here, thank you very much. Indeed, we did have our sensor mounted incorrectly. We are counting teeth like mad now and are very happy.
Thank you again and good luck at your regionals.
Mannie
Mannie Lowe
How close can you mount the IFI Controller to a CIM motor Capt. Quirk Control System 8 20-02-2008 19:37
How Close are you to done? Chuck Glick General Forum 26 16-02-2006 01:35
So Close!!!! Marygrace Chit-Chat 13 21-12-2003 18:16
So close, but not close enough archiver 2001 1 23-06-2002 23:45
how close will they call entaglement Andrew Dahl Rules/Strategy 4 18-02-2002 00:07
