Go to Post The only basis on which a team should be awarded the chairmans award is the content of the submission, not the way in which it is presented. - KenWittlief [more]
Unread 04-02-2007, 12:43
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
Bumper Mounts
How do you mount your bumpers? 1351 is currently in discussion about the best (and strongest) way to attach them.
thanks,
Sam
Unread 04-02-2007, 16:34
GVDrummer's Avatar
GVDrummer GVDrummer is offline
AKA: Jake Hall
FRC #0216 (RoboDawgs OTL)
GVDrummer is on a distinguished road
Send a message via AIM to GVDrummer
Re: Bumper Mounts
It would depend on how you would mount your chassie and what material it would be made out of. You could screw them to it or go as simple as zip ties which are really light.
Unread 04-02-2007, 17:07
Re: Bumper Mounts
The Tips and guidelines has some discussion on this subject. I saw all kinds of attachements last year but the ones that impressed me the most used a piece of aluminum angle drilled for mounting holes with bolts through the bottom of the chassis. The best one used eye bolts on the back of the bumpers which simply dropped over threaded rod on the chassis and attached with butterfly nuts. No tools needed and it only took a minute or so to remove for weigh in.
Unread 10-02-2008, 15:12
Kat Kononov's Avatar
Kat Kononov Kat Kononov is offline
AKA: artqny
FRC #2022 (Team IDK)
Kat Kononov is an unknown quantity at this point
Send a message via AIM to Kat Kononov
Re: Bumper Mounts
Are we allowed to use zip ties to mount the bumpers?
Originally Posted by manual
STANDARD BUMPERS must be
attached to the ROBOT with a bolt-and-
fastener system to form a
rigid, robust connection to the
ROBOT structure (i.e. not attached
with Velcro!).
Could someone please give some examples of "bolt-and-fastner" systems?
Unread 10-02-2008, 16:05
Re: Bumper Mounts
No. The GDC is very strict on the bumpers this year--it has to be something like a bolt-and-nut system.
Unread 10-02-2008, 18:30
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: Bumper Mounts
We use these with 1/4" 20 bolts. You just drill a 1/4" hole into your plywood and smack them in. Note that they need to go on the INSIDE of the bumper so that the bolt pulls them into the wood.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK019
Unread 10-02-2008, 20:19
Sam N.'s Avatar
FRC #1351 (TKO)
Re: Bumper Mounts
thanks,
Sam
I posted this a while ago and I've learned a lot since then. It is good to have your bumpers secured with big bolts but...
as long as the wooden backing of the bumper sits flush with your chassis, the bumper mounts only have to hold it in place. Any force imparted on the bumper should be translated to the chassis, not to the mount.
We use 1/4 inch aluminum angle. We may even downgrade that to save on weight.
Sam
Mitty Robotics Alumni
TKO 1351
Unread 10-02-2008, 20:26
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Re: Bumper Mounts
Team 1726 has used either t-nuts (which can be hammered into a wooden board) or t-bolts to mount their bumpers. A quick McMaster search will show the various hardware. Considering the directions in which force will be applied to your bumpers you shouldn't need an incredibly tough mounting system as most of the force will be transmitted right on through as noted above.
You should be more worried if your bumpers are unsupported in the center as they may shatter.
Unread 11-02-2008, 00:31
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Re: Bumper Mounts
We used 1/4-20 carriage bolts hammered in the spec-size plywood through a 1/4" thru-hole. Typically, only 2 bolts per bumper are needed. The square shank under the head bites into the plywood and keeps the bolt from turning while being tightened. The bolts ran through holes drilled into the side frame members (1.5"x1.5" welded aluminum tubing frame) and fastened by wing nuts that are hand tightened (i.e. no tools).
That is a very clever idea. Do you recall which team used that method?
We might look into using that ourselves--thank you!!
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 11-02-2008, 00:43
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Re: Bumper Mounts
Last year, a member of another team told us that we shouldn't leave any mounting hardware on the bumpers apart from the bolts and/or nuts. I am beginning to doubt whether we would've failed inspection had we left our angles on the bumpers.
Is it legal to leave some light mounting hardware on the bumpers for inspection?
Unread 11-02-2008, 07:26
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Bumper Mounts
No. The only mounting hardware that is legal to be on the bumpers at inspection is the nut/bolt fastener as described in <R08>. Any other mounting hardware must be attached to the robot and be included in the robot size and weight restrictions.
(since 2004)
Unread 13-02-2008, 20:57
[RMR662] Calle [RMR662] Calle is offline
AKA: Jon Zepf
Team Role: Driver
[RMR662] Calle is an unknown quantity at this point
Re: Bumper Mounts
Our team uses HDPE spacers to keep our bumpers offset the correct distance from our wheels. I understand these are most likely not legal bumper parts, and so will need to be included with the robot weight, but would it be acceptable to, after weighing in, reattach these spacers to the bumper, rather than the frame? For simplicity's sake, and just owing to the general design of our robot, this would be preferable.
Unread 13-02-2008, 21:08
Re: Bumper Mounts
That sounds like a good Q&A. Just remember that if you make finals, you'll have to take them off the bumpers again.
Unread 14-02-2008, 07:24
Re: Bumper Mounts
Calle,
What you describe sounds like the spacers should stay with the robot for weight and size. The inspector at your events will make the final decision once he or she examines your robot construction. Please plan accordingly.
Unread 14-02-2008, 08:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
Re: Bumper Mounts
This is our bumper mount system. The hex shaped standoffs are bolted to the chassis, and touch the bumper, but do not attach to it. The long coupling nuts in the corners are threaded onto the "fanged elevator bolts" that are mounted inside the bumpers. We used the long nuts to make it easier to handle the nuts without dropping them into mysterious crevices, and to have a lot more area to put the wrench on them.
Nypro Mounts Chris Dibble Motors 2 12-02-2004 16:32
Plastic Motor Mounts? Tonay K Motors 4 09-02-2003 20:28
Motor Mounts Eugene Technical Discussion 1 07-10-2002 22:20
Control System Mounts? archiver 2001 11 23-06-2002 23:33
Motor Mounts archiver 2001 3 23-06-2002 23:29
