Go to Post I respect what you have to say and I ask that you do the same for me. - Andrew Schreiber [more]
Unread 14-02-2008, 08:24
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
Robot controller lights question
We ran into a small problem with R<72> regarding the robot controller lights having to be visible 3 feet in front of the robot in playing configuration. Our robot has a cover for the electronics board and the robot controller is blocked by our gearboxes so even if we manufactured a lexan window the controller would not be visible from the front. Our proposed solution is to run a few lines of fiber optics up to the cover as the rule specifies that only the lights have to be visible. I am concerned with the legality of this solution. Does anyone know if this solution would be allowable?
Unread 14-02-2008, 09:49
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: Robot controller lights question
The rule is all I could find. I got this from the inspection checklist though;
230
Accessibility: 120A main circuit breaker, distribution breakers and RC are all accessible for inspection. In addition, the RC lights must be visible while standing 3’ from front of the robot while in its STARTING CONFIGURATION.
R50, R72
I would put this in the Q&A forum. Get it answered oficially.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 26-02-2008, 08:58
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Derek
We can always cut a hole in the cover and start in reverse. You said it was easier to drive that way too. I hope that our fiber optics are ruled legal as we are using the light from the RC and piping it to the cover.
FYI: We also used a 3D printer to make a plastic placard with text to duplicate the RC indicator text.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
FRC Robot Controller/Speed Controller RoarRoar Control System 3 17-01-2008 10:41
General question about the robot controller itsme Technical Discussion 6 14-01-2007 15:33
Lights on Robot ptan Technical Discussion 6 11-01-2007 15:44
Question About Robot Controller Pavan Dave Control System 4 03-01-2007 11:14
Christmas Tree Lights On The Controller Astronouth7303 Programming 1 05-02-2005 21:52
