Go to Post I personally need all the limbs and eyeballs I currently have, and I assume other feel the same way. - bfk [more]
Unread 14-02-2008, 09:32
Armando Gonzalez's Avatar
Armando Gonzalez Armando Gonzalez is offline
FRC #1872 (Yellow Fever)
Armando Gonzalez has a spectacular aura aboutArmando Gonzalez has a spectacular aura about
Send a message via MSN to Armando Gonzalez Send a message via Yahoo to Armando Gonzalez
Working pressure problem
What is defined as "working pressure" of the robot, also what and where do we need to add the additional needle to view it.
Oh, and we are having a problem, our pressure switch is turning off the compressor at 115 psi. We tried adjusting the set screw, but nothing happend.
Thanks
Armando Gonzalez
Team 1872 - Yellow Fever
San Juan, PR
Awards
Rookie Inspiration Award - 2006 UCF Regional
Unread 14-02-2008, 09:42
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: Working pressure problem
The working pressure for the robot would be 60 psi. See the Pnumatics manual under "regulators."
http://www.usfirst.org/uploadedFiles...ics_Manual.pdf
The pressure switch will turn off the compressor at 115-120 psi. The accumulators will have that much pressure in them. The actuators cannot run at 115-120 psi. That is what the pressure regulator is for. It MUST be placed BEFORE ALL working componnents on the robot. It only lets 0-60 psi through to the actuators.
As for the pressure switch, I don't know, sorry.
Good luck,
Jacob
Do what you like... Like what you do!
Jake, the Life Is Good guy
Pressure Gauge neoshaakti Pneumatics 1 25-01-2008 20:50
[OCCRA]: Problem with the compressor, pressure switch, or Bosch relay. BrittanyV OCCRA 3 16-10-2006 15:42
Got it working now theres another problem! cdennisxlx2 Programming 11 25-03-2006 21:58
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
