Go to Post Lesson learned: don't hide cables where drills can find them! - Richard Wallace [more]
  #46   Spotlight this post!
Unread 14-02-2008, 10:23
t-raum's Avatar
t-raum t-raum is offline
AKA: Jeremy Traum
FRC #1625 (Winnovation)
t-raum is an unknown quantity at this point
Send a message via AIM to t-raum
Re: Shooters vs Arms
A shooter I think is the best way to go even during end game. As long as you have a device that can knock the ball off the overpass at the end. The shooter can hurdle and then knock te opponents ball off the overpass to create a 22 point gain for the alliance who can do this. If a team can pull this off end game would be very interesting.
T-raum
  #47   Spotlight this post!
Unread 15-02-2008, 22:35
Captain Sugar Captain Sugar is offline
AKA: Ben Cassidy
FRC #2354 (Wheelie Bots)
Team Role: Tactician
Captain Sugar is an unknown quantity at this point
our shooter is almost like an arm in its attributes. it can pick up the balls really easily, using a set of rings on the front. however, when it shoots, the pneumatics contraption pushes out too far and actually pushes the robot off the ground, so we can't shoot on the go. it shoots the ball really far, though.
  #48   Spotlight this post!
Unread 16-02-2008, 07:23
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
What about an arm that can kind of act like a shooter?
Our robot has a claw system that grabs the ball from the floor and then the arm goes up about 70-80 degrees while the claws themselves rotate to be horizontal. We can drop the ball onto the overpass but we're not sure it can go over the overpass easly.
That's why we're trying to implment a function in the programming area that will bring the arm back 135 degrees(!) and once the robot is in position and the button has been pressed, the claws will rotate at full speed and will release the ball in the midst of the whole action which will cause the ball to fly over the overpass.
Now, I'd call that a thrower, which can count as a combination of an arm and a shooter.
pros?
- Doesn't have to position itself specificly in order to make the ball pass the overpass.
- Cannot be blocked.
- Can put the ball on the overpass.
(- can catch the ball on the run.) - to be tested.
Cons?
- it can take about 6-5 seondes to get the arm and claws in shooting position, might be some disadvantage.
There's probablly more that I just can't point them out 'cause I haven't went through them yet...
Your opinions about this?
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
  #49   Spotlight this post!
Unread 16-02-2008, 09:16
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Shooters have the advantage. Most arm bots will have to stop moving before they can hurdle the trackball and they are limited as to where they must be in the home zone (close to the overpass) when they lift and hurdle the trackball. A good shooter will be able to hurdle the trackball on the fly from at least a third of the floor space in the home zone. Several people have talked about a shooter not being able to pick up a trackball as fast as an arm bot. I believe that you will have shooters that can pick up a trackball just as fast as any arm bot out there. Placing the trackball is way over rated. Given the speed of a shooter vs an arm bot that places. The shooter should be easily able to get more hurdles than an arm bot to make up for a single 12 point placement. Also, you will never see a shooter get clothes lined by the overpass.
IMPEDING: Preventing or obstructing an opposing ROBOT’S ability to proceed around the TRACK in the direction of traffic.
As for blocking a shooter, all a shooter has to do is head directly towards the blocker, just before it gets to the blocker, veer left or right and launch, if the blocker moves to get back in front of the shooter, the shooter just earned negative points for impeading.
  #50   Spotlight this post!
Unread 16-02-2008, 14:24
Eye-gor's Avatar
Eye-gor Eye-gor is offline
NO LONGER THE ONE GIRL IN THE SHOP!
AKA: J.R.
FRC #1388 (Eagle Robotics)
Eye-gor is an unknown quantity at this point
Originally Posted by ggoldman View Post
Here are some pros and cons I see of both:
Shooters
Pros:
Quick release
Can hurdle "on the run"
Cons:
Cannot Place on Overpass at end
Can be "Blocked" easily
Cannot (on their own) knock down balls off overpass
Arm lifters
Pros:
Can knock balls off overpass
Can place on overpass at end of game
Cannot be "Blocked" while hurdling
Cons:
Slightly slower than shooters
Possible High Center of Gravity
But you haven't gone through all the possibilities. the hardest part of this year's game (design-wise) was choosing a direction to take, whether we'd catapult the ball, or use an arm...or a combination of both.
Dr. Frederick Frankenstein: You must be Igor.
[He pronounces it ee-gor]
Igor: No, it's pronounced "eye-gor."
Dr. Frederick Frankenstein: But they told me it was "ee-gor."
Igor: Well, they were wrong then, weren't they?
  #51   Spotlight this post!
Unread 16-02-2008, 15:48
jimbot's Avatar
jimbot jimbot is offline
FRC #2083
jimbot will become famous soon enoughjimbot will become famous soon enough
You can't really block the ball. unless Im mistaken there is a rule prevnting oppossing robots to be over 5 feet in your home stretch.
As for shooter vs. arm, please watch lower video. If 118 can remove over head ball, then they will be amazing using that SHOOTER!
http://ca.youtube.com/watch?v=CAJBC-DDL9w
  #52   Spotlight this post!
Unread 16-02-2008, 15:50
You are mistaken. Please read the current edition of Section 7 and Updates 1 and 2.
There is now no height restriction, other than the physical limits of the Overpass.
  #53   Spotlight this post!
Unread 17-02-2008, 14:00
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
I think the biggest con with shooters will be air usage (assuming most are using pneumatics). Ours has 2x 2" and 2x 1.5" by 10" cylinders. After a launch our air tanks loss a lot of air, but can still operate at 50+ psi. 1726 has has provided some great advice on air conservation in a couple threads. As long as teams can keep air in their tanks (and a little in the cylinders ) Shooters will dominate the field.
side note: even if some teams have air problems, strategy could compensate for their recharge time.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
  #54   Spotlight this post!
Unread 17-02-2008, 14:09
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
I personally like the arm bot for the reason that our robot was designed with plug and play in mind, we wanted to in case of mistake or error be able to remove that whole 'arm' assembly, and replace that with a bumper/herding device. To answer your next question, yes we are that far under wieght, 835 holes pre cut, 95 lbs W00t!
Is now an engineer thanks to FIRST.
  #55   Spotlight this post!
Unread 18-02-2008, 11:04
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
In the scrimmages, has anyone seen how shooters did especially as related to arms?
Doug Leppard
  #56   Spotlight this post!
Unread 18-02-2008, 12:51
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
In my humble opinion the entire game is ball acquisition...it doesn't matter what your method of getting the ball over the overpass is....The teams that are best at grabbing it quickly will be the best teams hands down...
Chris C.
Team 151 | Alumni | 2000-2002 | Nashua High School
Team 229 | Alumni | 2003-2006 | Clarkson University
Team 148 | Alumni | 2007 | RackSolutions.com
Team 177 | Engineer | 2008-? |
  #57   Spotlight this post!
Unread 18-02-2008, 13:36
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
I agree with this. Effectively grabbing the ball quickly and moving around the field to get in position to score is important.
The one thing I keep hearing from all these threads is that, if you lose autonomous by 15-20+ points, its too hard to overcome if both alliances can fairly hurdle, herd, and do laps.
I'm not so sure if even the best hurdler on an alliance can overcome 20+ points, when everyone else can score, there will be traffic, and only 2 balls per alliance.
  #58   Spotlight this post!
Unread 18-02-2008, 14:45
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
A well designed shooter (IMHO) can outscore most arm designs. It should be able to:
Acquire quickly.
Shoot on the run.
Avoid legal blocking maneuvers.
Place the ball on the overpass.
I know of at least one such arm.
http://www.youtube.com/watch?v=QeQSGmFnKAE
One big problem with arms is the CG. While lifting the 8+ pound ball 6 1/2 feet off the floor, the CG is very high. I saw several arm bots go turtle at the scrimmages.
  #59   Spotlight this post!
Unread 18-02-2008, 14:50
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Originally Posted by s_forbes View Post
Who says a shooter robot can't take a ball down and put it back?
You mean like this: http://www.youtube.com/watch?v=T5d34yZrSH0
Phil Malone
http://www.GEARSinc.org
  #60   Spotlight this post!
Unread 18-02-2008, 17:08
waialua359's Avatar
AKA: Glenn
Acquire quickly.
Shoot on the run.
I think it depends on the bot. I'm pretty sure some bots will be very stable while lifting and scoring. We throttled full speed from dead rest with our ball straight up in the air (and vice versa), and our robot does not tip at all.
I'd be more scared of a shooter launching a ball dead square on our bot, although I think we would survive. Some of the bots that I have seen have ball grabbers that look so flimsy like they'll break with a little impact.
Horizontal Shooters Sachiel7 Technical Discussion 10 24-02-2006 08:12
2 Shooters??? Jon Jack Robot Showcase 14 26-01-2006 20:00
Shooters or Nonshooters Kevin_547 Rules/Strategy 6 21-01-2006 22:28
Female Shooters JulieB Championship Event 29 28-04-2004 16:47
Pure Shooters Andrew Rudolph General Forum 5 04-03-2002 20:53
