Go to Post Gracious Professionalism, it's hard to describe, but I sure know when I'm not living up to it. - rsisk [more]
Unread 13-02-2008, 20:07
bilal1219's Avatar
bilal1219 bilal1219 is offline
AKA: Bilal
FRC #1219 (Iron Eagles)
bilal1219 is an unknown quantity at this point
IR board.
Hi, I just wired my board recently.Here is the problem, When i hooked up the board it was working like the error led would light up and then turn off until i press the white button and the CMD 0 Lights up. The thing is when i hooked the Wire up on the 9v battery then i got is the error LED lighted up for 1 sec and then truns off and dosent light up again and even if i press the white button nothing happens. when i plugged the IR in the Fuse panel it still did the same thing. and when i took it out of the fuse panel,it did not work at all, even though i made sure that my wirings are correct. I checked wheather they are all getting voltage after i rewired it,I saw that only the wiring ribbon and the board is getting powered. The IR reciver is not getting powered.
I even read the post from before, Teams have said that its the regulator. But in this case does someone think its the regulator or not.Thank you for your help.
If someone has spare IR we would love to have it.
Bilal Shahid
Team 1219
<a href="http://www.thebluealliance.net/tbatv/team.php?team=1219" style="border: 0"><img src="http://www.thebluealliance.net/tbatv/teambadge/gen/1219/FF3300/0066FF/teambadge.png" alt="Team 1219" /></a>
Robots Might Lose But Teams Never Do
Unread 13-02-2008, 20:20
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: IR board.
do you have 12 volt main power going into it as well?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 13-02-2008, 22:37
bilal1219's Avatar
AKA: Bilal
Re: IR board.
No, When i connected it up with a backup battery i did not connect it with main 12 V,before it stopped responding.but i also noticed that if i connect it to Digital In/Out on RC, I get the signal indicating that the switch is connected on OI?im wondering is this programming error, Like are we suppose to prgram it first and then train the board.
Bilal shahid
Team 1219
Unread 13-02-2008, 22:48
AndrewSTA AndrewSTA is offline
FRC #2574
AndrewSTA is an unknown quantity at this point
Re: IR board.
Bust out your multimeter and check the voltages on either leg of the 5v regulator (it's big and black, first big thing that comes off the power pins) and check the voltage on either leg. If you get 5, that could be good depending on your view of it, your 5v regulator is good but something else is wrong. If you get nothing, your regulator is most likely dead and you will need to replace it with a piece from digikey (although time is running out) or you can buy a 7805 from radioshack and solder it in place of the current one.
Unread 14-02-2008, 00:06
bilal1219's Avatar
AKA: Bilal
Re: IR board.
Also, Guyz, Since i didnt want to open another thread, i wanted to post it on this one.
we have an autonomous switch and we have it plugged in digital input 1 and we wanna use it in autonomous like when we switch it on it starts.Is there a way of doing this.
Bilal Shahid
Team 1219
Unread 14-02-2008, 09:32
Miner Miner is offline
AKA: Jacob Miner
FRC #2077 (Laser Robotics)
Miner is on a distinguished road
Re: IR board.
That is an interesting idea. The game will be started automatically and the autonomous/hybrid period starts when the ref's say so. You wont be able to physically flip the switch on the robot.
Or are you talking about a button on the control board?
Do what you like... Like what you do!
Jake, the Life Is Good guy
Unread 14-02-2008, 11:00
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: IR board.
If U R Bored, then go build a robot!!!
Ohhh... wait... that's not what you meant by the title???
My bad.
/moving right along...
Unread 14-02-2008, 12:07
bilal1219's Avatar
AKA: Bilal
Re: IR board.
Yes, thats what i mean, to mount the switch on the control system which will perform this task.
Unread 14-02-2008, 13:40
RyanW RyanW is offline
FRC #0449 (Blair Robot Project)
RyanW has a spectacular aura aboutRyanW has a spectacular aura about
Re: IR board.
There is already a Competition Port on the Operator Interface which should let you do just that...You'd need to get a switch and wire it up to the proper pins. I don't really know electronics, but the pinout guide is here: http://www.ifirobotics.com/docs/comp...guide-reva.pdf and this thread should have some more info.
Unread 14-02-2008, 16:21
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: IR board.
As posted previously I am unsure of why you would want to do this. If you do this though you will have to take into account that you robot will be dissabled, so any code will not be able to be run.
1458's board Andy L Electrical 5 26-01-2008 22:22
IR board joshuamorris Electrical 2 12-01-2008 19:43
IR Board? Pavan Dave Rules/Strategy 3 06-01-2008 19:10
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
