Go to Post What language does your programming mentor have the most experience with? That's the language you should use. - Rosiebotboss [more]
Unread 14-02-2008, 16:32
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Re: KOP Gyro Lag
Originally Posted by Kevin Watson View Post
Can you zip up your build directory and e-mail it to me? Also, make sure you've plugged the gyro into channel one. If you plug it into a different channel than specified in gyro.h, the ADC can still read residual charge from the sample-and-hold capacitor if that input is floating. How is the gyro wired? Perhaps it's output driver is weak and having a tough time driving the capacitance of the cabling? Ideally, the cable should be as short as possible.
-Kevin
Sure. I'll send you our version that uses your code. We also have a version that uses IFI's base code. Both exhibited the gyro lag problem.
The topic that I linked to above tells me it isn't an ADC problem, since the person who posted that topic tested the same analog input with a POT and there was no lag at all.
Lag Issue bizarospooky Programming 7 08-02-2008 17:31
Some 2007 KOP Gyro Performance Data yoyodyne Control System 3 02-04-2007 20:07
KOP Gyro seems to run-on after turn stops PhilBot Control System 8 05-03-2007 12:43
KOP Gyro John Gutmann Programming 12 12-12-2005 21:59
Lead-Lag Compensator eSouL Control System 0 13-08-2004 03:21
