Go to Post If it's good enough for Star Trek, it's good enough for FRC. :) - KarenH [more]
Unread 14-02-2008, 15:32
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
Question about pneumatic cylinder connection
Is it OK to connect the pneumatic cylinder to our arm by tying it with a very strong rope (this rope is a metal wire inside and I think silicon wrapping).
2007 Israel Regional GM/Technion Rookie Allstars
Participated in 2007 Atlanta World Championships (Newton Division)
Unread 14-02-2008, 15:45
Team 135 Team 135 is offline
FRC #0135 (Penn Robotics)
Team 135 will become famous soon enough
Re: Question about pneumatic cylinder connection
The only problem with that, at lease that I can see, is the durability of the rope. It seems the constant vibration of the robot may cause them to slip.
Unread 14-02-2008, 15:59
FRC #2217 (FOMH)
I connected the rope and caught it very strong with hooks with screws on them.
It's not a tie actually, it's more like screwing the rope together.
Unread 14-02-2008, 16:16
just to be sure I would check the rule book to be absolutly sure that there is no rule against using rope, I am pretty sure that there is not but better safe than sorry. Other that that I would try to move them with you hand and make a determination on how much they actually move.
Unread 14-02-2008, 16:50
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Better than rope, you might want to try some "plumbers tape", or metal strapping. You can wrap it around the cylinder and a supporting member pretty easily, and screw it in. Last year, we used it for one of our cylinders (not on an arm) and it passed inspection just fine *although there's no guarantee this will be the same*. We haven't used string, but we have used stranded metal cable to secure things. This year it's being used to move our elevator, and last year it was used as a secure and release mechanism for our ramp (it attached to the top of the ramp and ran down to the aforementioned cylinder, which would release the cable when we wanted to lower the ramp).
Unread 14-02-2008, 16:58
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Rope is fine. As a general rule, unless something is a motor, electrical component, pneumatic component, highly dangerous, or extraneously expensive, the material can be used. However, you should always check the flowchart if you aren't completely sure.
Unread 16-02-2008, 10:21
feliks_rosenber's Avatar
feliks_rosenber feliks_rosenber is offline
Félix
AKA: Mentor of Teams #2217 & #2669
FRC #2217 (FOMHA & KY Bots)
feliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the roughfeliks_rosenber is a jewel in the rough
Send a message via MSN to feliks_rosenber
I mean that the end of the cylinder piston is connected by metal rope to the arm. Is it OK?
Visit team 2217 channel:
http://www.youtube.com/profile?user=team2217
2007 Israel Regional GM/Technion Rookie All Stars
______________________________________________
Visit team 2669 channel at:
http://www.youtube.com/user/team2669
Unread 16-02-2008, 15:53
Nothing against using cable in that way.
Unread 16-02-2008, 17:18
FRC #2217 (FOMH)
OK, just to be sure, here are some photos of what I'm talking about:
http://www.picoodle.com/view.php?img....jpg&srv=img26
Unread 16-02-2008, 17:25
No materials rules are broken, right? If so, then there is nothing saying you can't use that connection.
Unread 16-02-2008, 17:35
FRC #2217 (FOMH)
OK, thank you very much!.. Sorry for the bothering.
pneumatic cylinder help. Brandon_L Pneumatics 2 26-01-2008 10:55
Pneumatic Cylinder yanksrock777 Technical Discussion 2 20-02-2007 11:01
Pneumatic cylinder size bruss6 Pneumatics 8 16-02-2007 16:37
Pneumatic Cylinder Length billy Technical Discussion 2 10-01-2003 08:30
2" Pneumatic Cylinder Posted Ed Sparks General Forum 0 27-01-2002 15:47
