Go to Post we used to walk barefoot through five feet of snow to get to school, uphill both ways, with just barbed wire for mittens, and we liked it! - dlavery [more]
Unread 14-02-2008, 17:14
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: Does the Norgren Pressure Regulator show working pressure or stored pressure?
Originally Posted by M. Krass View Post
This is so much work for one lousy actuator, but that actuator will make our robot work so much better.
Just out of curiosity, what does this one actuator do? What size and stroke.
The reason I ask is, there is a rule of thumb for using pneumatics. Use them if you can do two or more functions with them. ie. A shifter and a lever etc. Sometimes the weight added isn't worth it if only one function is added.
As with all "rule of thumbs", there are exceptions, such as, it is the best way to do what we need.
If you can leave the compressor off-board, you have fairly well handled the weight issue.
Unread 14-02-2008, 17:22
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The actuator rotates our ball manipulator up against the robot to better control the ball. We had designed a built a claw-type manipulator, but weren't happy with ball control, so we've switched to something a bit simpler, but more effective. For it to operate properly with motors, we'd need either a worm or screw drive to prevent stalling the motors for long periods of time.
The pneumatics allow us to quickly control the position of the manipulator and we only have to worry about managing a single pneumatic tube -- since we're planning to vent to atmosphere on the actuator, I think -- along our lift's extension.
Luckily, weight is of little concern to us right now. We've swapped a 17 lbs. claw mechanism for a 4 lbs. manipulator. We're well below our weight restriction.
--Madison--
...down at the Ozdust!
Unread 14-02-2008, 17:31
billbo911's Avatar
As long as you are using a 3/4" dia., short(ish) stroke piston, you should be just fine with the compressor off board.
As an example:
We tested a 3/4" dia. 5" stroke piston on 60 PSI working pressure in 4 Clapard storage tanks. We only lost about 1 PSI per stroke. We were able to cycle the piston 25 times w/o much of an issue. The last 5 cycles were a bit weak.
Unread 14-02-2008, 17:40
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
Then you have plenty of weight available to have the compressor on-board, and not have to worry about the hassle of having it off-board. (: In my experience, having it off-board is a hassle - you have one more thing to do/check between each match; you have to be extra careful about avoiding a leaky pneumatics system (I've never seen one that's 100% leak-proof); if you have delays before starting the match, the leaks add up that much more. We've used an off-board compressor in the past (when our only pneumatics was shifting), and it worked, but if you have the weight, I would recommend against it. You could always put it on, and plan that if weight becomes an issue, it's the first thing you take off.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Nason Pressure Regulator Calvin_1631 Pneumatics 9 09-02-2006 00:40
Nason pressure regulator...HELP!!! Bob Steele General Forum 0 25-02-2004 16:08
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
