Go to Post Tell them your newfound passion for FIRST as a program, and let them know all you're doing is getting more involved to broaden your FIRST horizon - Dorienne [more]
Unread 14-02-2008, 17:30
amityschool
Posts: n/a
pic: Our robot holding the Ball
Unread 14-02-2008, 17:40
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: pic: Our robot holding the Ball
that ball looks pretty deflated is it 40 in?
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 14-02-2008, 18:02
robotboy11's Avatar
robotboy11 robotboy11 is offline
FRC #1708
robotboy11 will become famous soon enough
Send a message via AIM to robotboy11
Ur out of the 80" cylinder area! Make sure you read r9Q
Good Luck
Team #1708
Kevin
Unread 14-02-2008, 18:03
robotboy11's Avatar
FRC #1708
Ur out of the 80" cylinder area! Make sure you read R16 carefully.
We actually had the same problem, but we fixed it now.
Good Luck
Team #1708
Kevin
Unread 14-02-2008, 19:31
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
Its no longer a cylinder area. Its an 80 x 80 square. But either way, yes your out. Unless you have some sort of algorithm to pivot the claw in towards the robot as your lifting it (looks like you have a joint there). We were thinking about doing something like that.
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 14-02-2008, 20:10
superjew4865's Avatar
superjew4865 superjew4865 is offline
FRC #1816
superjew4865 is an unknown quantity at this point
the dimensions of the 80in cylinder never changed just to tell you and you might want to recheck the rule book.
Unread 14-02-2008, 20:35
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Did the rule ever say the center of the cylinder had to be the center of the robot?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-02-2008, 20:44
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
No the rule just states that the maximum possible horizontal distance can only be 80", so they would have to measure the end of the left side of their forks when their arm is at 90 degrees, then horizontally to the back right side of their base. My guess is that it looks like they are over 80" but they would have to measure it to be sure.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 14-02-2008, 20:47
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
It was never an 80 in circle, and it is not now an 80 in square. Edit: Mr. Norris beat me to it....
The rule limits the maximum horizontal dimension. This means that there are cases where the robot won't fit the circle or the square, but will satisfy the rule.
The talk of a cylinder came from an example in the rules which mistakenly gave the impression that fitting within an 80 in circle was a requirement. It has long since been clarified by FIRST.
Unread 14-02-2008, 21:34
iwashere1990's Avatar
iwashere1990 iwashere1990 is offline
Team 1389's Everything
AKA: Jason
FRC #1389 (The Stig)
iwashere1990 is an unknown quantity at this point
our robot is exactly the same design (arms/claw).
thanks to this thread, I will check if we made 80in.
we though our robot design was unique, I guess it's not.
Good Luck Teams, 5 days left
"Achievement is not always success while reputed failure often is. It is honest endeavor, persistent effort to do the best possible under any and all circumstances."
Team Number:1389
My Job on the Team:Everything but Programing
My Rookie Year:2007
My Team's Rookie Year:2004
Awards: Zero
Number of Members: 7-9
Number of Mentors: 1 (more like zero)
Our Current Budget for the Team: -6,000$
Number of Headaches this Year: 4
Number of Colds: 1
Number of PHAILS: > 10
Team 467 Driving while holding the ball Tsom467 Robot Showcase 18 16-02-2008 01:02
pic: FVC 3063 Holding Atlast Ball AdamHeard Extra Discussion 4 07-08-2007 22:48
Holding a position in our arm brennerator Programming 2 17-02-2007 04:02
pic: Holding the big ball CD47-Bot Robot Showcase 12 23-02-2004 22:14
Robot holding a ball... WIP ..image Salik Syed 3D Animation and Competition 7 03-01-2004 22:27
