Go to Post Hallry's back! Tell a Friend! - Tyler Olds [more]
Unread 14-02-2008, 19:40
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Exclamation Help again with Servo Programming
Hello, this is what i came up with for shifting with a servo... It doesnt seem to work and was wondering if anyone knew how to do it. If p1_sw_top button is hit, it shifts pwm15 and pwm16 into high gear (255) if the p1_sw_trig is hit, it needs to shift into low gear (0). How can i make this work? PLEASE HELP!!!
if ((p1_sw_top == 1)) // If Top Button on Joystick 1 is hit
{ // Make the two servos.......
pwm15 = 255;
pwm16 = 255;
else
pwm15 = 255;
pwm16 = 255;
if ((p1_sw_trig == 1)) // If Trigger is pushed on Joystick 1
pwm15 = 0;
pwm16 = 0;
else
pwm15 = 0;
pwm16 = 0;
Servo Programming Again..... programmr Programming 1 14-02-2008 09:31
Help with programming Armando Programming 1 25-01-2007 18:41
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Help with Programming double_check Programming 11 19-08-2005 00:15
Help With Programming! KWalsh Programming 5 24-02-2004 11:42
