Go to Post Here is more data, Because we all love data. - Bochek [more]
Unread 14-02-2008, 19:40
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Exclamation Help again with Servo Programming
Hello, this is what i came up with for shifting with a servo... It doesnt seem to work and was wondering if anyone knew how to do it. If p1_sw_top button is hit, it shifts pwm15 and pwm16 into high gear (255) if the p1_sw_trig is hit, it needs to shift into low gear (0). How can i make this work? PLEASE HELP!!!
if ((p1_sw_top == 1)) // If Top Button on Joystick 1 is hit
{ // Make the two servos.......
pwm15 = 255;
pwm16 = 255;
else
pwm15 = 255;
pwm16 = 255;
if ((p1_sw_trig == 1)) // If Trigger is pushed on Joystick 1
pwm15 = 0;
pwm16 = 0;
else
pwm15 = 0;
pwm16 = 0;
Unread 14-02-2008, 19:43
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Help again with Servo Programming
you have a contradiction with your elses
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 14-02-2008, 19:45
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Eliminate your ELSE cases and everything should work fine. They're negating the effect of the first IF and always set the PWMs to 0. You also may want to find the values at which the gear engages, but does not push the servo beyond its mechanical limit. Although I'm not sure it is needed.
Unread 14-02-2008, 19:56
programmr's Avatar
AKA: Face
FRC #0522
hey thank you guys so much!
Servo Programming Again..... programmr Programming 1 14-02-2008 09:31
Help with programming Armando Programming 1 25-01-2007 18:41
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Help with Programming double_check Programming 11 19-08-2005 00:15
Help With Programming! KWalsh Programming 5 24-02-2004 11:42
