Go to Post I don't care if students, engineers, my aging grandmother, or a pack of monkeys builds the robot...as long as at least one student walks away inspired then the goal of FIRST has been reached. - Andy Grady [more]
Unread 09-02-2008, 19:26
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
Exclamation Festo valve help
When we turn on our robot the pneumatic cylinders extend until 30psi when the festos kick in, then they will retract to where we want them at the start. Is there any way to stop this from happening and is this normal for the festo's?
Unread 09-02-2008, 19:31
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Festo valve help
The Festos, in addition to needing 12 Volts, need 30 PSI to kick over as they are pneumatically controlled.
Thus, if you are trying to start with the Festos active and no pressure in your tanks (plumbed to keep your cylinder retracted when the festos are active) then you will get that reaction.
My suggestion is to charge the tanks first (before starting the RC).
___________________
- Tennyson, Ulysses
Unread 09-02-2008, 22:41
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
You could use the SMC solenoids. They will remain in the position they were last set until power is applied to one end. Granted, they won't change until there is enough pressure applied to them, but they won't do what the Festos are doing.
Unread 11-02-2008, 07:34
jskene jskene is offline
None #0612
jskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to beholdjskene is a splendid one to behold
You could reverse the ports on the valve, so that when it powers up, it's already in the desired state.
Jerry Skene, mentor OOO OOO 2010 - Chairman's Award- DC OOOOOOOOOOOOOOOOOOOOOOOOOOO
Chantilly Academy, Team 612 - 2009 - Engineering Inspiration Award; Finalist - New Jersey
-----------------------------------2008 - Chairman's Award; Kleiner Perkins Award -Buckeye ---| ---Team Spirit Award - NASA/VCU
-----------------------------------2007 - Chairman's Award - NASA/VCU ---| ---Finalist; Kleiner Perkins Award - Chesapeake
-----------------------------------2006 - Chairman's Award - Chesapeake ---| --- Engineering Inspiration Award - NASA/VCU --
Unread 11-02-2008, 21:18
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Question Re: Festo valve -- how to order more
We had one break and need to order more.
I went to the website but there is no part number 13026684 when I did a search. Any clue as to where to get them and fast.
Thanks so much in advance.
Carolyn
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 11-02-2008, 23:50
Racer26 Racer26 is offline
Carolyn
I don't know about the FESTO valves, but I know here in southern Ontario there's a number of pneumatic supply place where we've picked up some SMC valves, which should perform your needed task.
Alternatively, you could just use the SMC valves out of the kit.
Unread 14-02-2008, 20:07
FRC #1254 (Entropy)
Re: SMC valves
They "Disappeared".
I have called more than one SMC listed distributor.
They still do not show the part number in their SMC system. The part listed is SY3240-6H-S. They do not have that in the
SMC system according to the 2 distributors I called. They have a part SY3240-6HZ-X70 which was the one from last year.
The SY3240-6HZ-X70 they have 150 on the warehouse shelf. I do not know what to do. We need one.
I also put a question on Q&A but it has been over 48 hours with no answer.
Please can any team help us decide what to do.
The SMC ones are $83.00 each, so I do not want to order the wrong one.
What about <R34> and <R42>, even though we are in the USA.
Is there anyone not using theirs? We could pay for shipping, buy it, etc.
Carolyn
Unread 14-02-2008, 21:41
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Don't you have the double SMC's from the past? I'm pretty sure they're the same valves.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 14-02-2008, 23:18
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: SMC valves
They "Disappeared".
No answer? Did you check here? It seems that the answer to your question was posted several hours before it was said "there was no answer."
Unread 15-02-2008, 09:17
FRC #1254 (Entropy)
Red face Re: SMC valves
I really did look before I posted. One of our two questions showed up but this one had a lock on it. I now know why I did not see it. I thought I put the question in Section 10 - Kit of Parts, but this answer is in Section 8 - The Robot - pneumatics. I kept looking in Section 10 for the answer and did not see it. My appology to all, especially the person who answered our question in a very timely manner. Next time I will check better before I post.
Carolyn
Teacher who obviously needs rest.
what is the festo valve connected to? Reaper40 Pneumatics 1 26-01-2007 18:15
2004 Festo Valve Not Available ..... Ed Sparks Pneumatics 6 02-02-2004 19:28
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
trouble with assembling FESTO valve geo Pneumatics 15 02-02-2003 09:28
Festo Valve Gary Bonner Pneumatics 2 26-02-2002 17:48
