Go to Post I found the best way to slice through pit crowds is to carry a clipboard and look like you know where you are going. People just seem to slide out of your way. :) - Ian Curtis [more]
Unread 14-02-2008, 22:45
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
The slate
So, I had to make a 30 second animation this week...and i'm reading about putting in a 5 second slate and a second of black before the animation. How does one go about doing this?
thanks
Unread 14-02-2008, 22:52
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: The slate
you need:
Your highschool name,
team name
team number
how many seconds the animation is
and if it is stereo or mono
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 14-02-2008, 22:53
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
Re: The slate
how do i add it to the animation though?
Unread 14-02-2008, 22:59
BuddyB309's Avatar
AKA: Peter Casey
Team Role: Animator
Re: The slate
add it in a 3rd party program, or have a plane with the picture of text on it and switch it out with a plane of black
A.K.A Llama
Unread 14-02-2008, 23:01
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
Re: The slate
which would be easier? Can you add frames into the beginning of the animation without messing it up? Im a total newb at this.
Unread 14-02-2008, 23:02
adamrw91 adamrw91 is offline
FRC #0701
adamrw91 is on a distinguished road
Re: The slate
well if it depends on wether you have a video editor or not.
if you arent you could just add a plane with a texture on it with the info straight on it.
thats the lamemans way
lol
Unread 14-02-2008, 23:04
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
Re: The slate
But I'll need another 180 frames in 3ds max to do that at the beginning...
That would screw me up, unless there is any easy way to shift the frames that I have. What video editor would you suggest thats free and easy to download?
Unread 14-02-2008, 23:15
FRC #0701
Re: The slate
ok i got a free video editor.
virtualdub.org
this is a freeware video editor not to fancy but works fine.
i havent used it but ive heard it woorks half decent.
Unread 14-02-2008, 23:19
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
Re: The slate
thanks. I just downloaded the combustion software as well...hopefully I can get something out of this...uggg
Unread 14-02-2008, 23:21
FRC #0701
Re: The slate
heres another 1 if that 1 dosent work. this 1 hase a little more resources it might be better but i dont know how good it is.
http://jahshaka.org/
Unread 14-02-2008, 23:34
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
Re: The slate
thanks, well, I'm trying to render it now, wish me luck
Unread 15-02-2008, 10:34
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
Re: The slate
alright...well I got it all done, in 4 hours, and the file size is 160 megs over the 250 meg limit. Any way to decrease that?
Unread 15-02-2008, 11:15
FRC #0701
Re: The slate
are us sure u compressed it with a ntsc-DV1 compresser?
is it 29,97 frames per second?
otherwise im not totally sure what settings are wrong
Unread 15-02-2008, 12:39
dario dario is offline
FRC #1730
dario is an unknown quantity at this point
Re: The slate
To add time at the beginning of the animation:
Click on the time configuration at the bottom right of your screen. You can choose to have the scene start at negative time. This will allow you to put 180 frames in front of your animation while keeping all other keys where they are.
Unread 15-02-2008, 14:35
rastermon rastermon is offline
FRC #0847
rastermon is an unknown quantity at this point
Re: The slate
I think the best way is to add it in an editor.
Such as Video post that comes with 3DSMax - render menu -- video post
Or with Combustion that is also from Autodesk.
Make your slate and credits images - can even use powerpoint and save as a jpeg.
then import those images into the video post timeline.
Piece together your 5 sec title, 1 second black, then your animation (whether its a series of tif images or an already compressed QT mov)
Add 1 second of black to the end.
The render the edit. (this takes much less time than the original 3D render).
Make sure its NTSC-DV Quicktime 720 x480
The only prob with 3DS Video Post is no audio capability.
Good luck!
From the Ice Age to Robot City. The Few, The Proud, The Machines (new movie) Elgin Clock Televised Robotics 21 14-03-2005 15:14
???Black slate jason_931 3D Animation and Competition 6 06-02-2005 22:52
Survey of the 2004 NJ Regional- The good, the Bad and the So-So Rich Wong Regional Competitions 23 10-03-2004 06:23
pic: The Man, The Myth, The Legend, The Symbol CD47-Bot Extra Discussion 6 09-04-2003 02:48
