Go to Post Humility tends to take people places, pompous boasts tend to get people left at home by themselves. - Karthik [more]
Unread 14-02-2008, 15:14
BurnFischer's Avatar
BurnFischer BurnFischer is offline
The Driver
AKA: Silas Fischer
FRC #1824 (Team Apollo)
Team Role: Driver
BurnFischer will become famous soon enough
Send a message via AIM to BurnFischer
Dewalt Transmission Crisis!
Running 4 DeWalt transmissions on our robot, chain driven so that 2 of the transmissions are running 2 wheels. Unfortunately the victor's are setting the motors at 2 different speeds and tightening up one end, loostening up the other. When we run the 2 motors out of the same Victor, they are syncrod close enough that the wheels run, but when we stop it seems to lock up. Is there any way we can keep them being driven on through 1 chain, or should we split it and chain 1 wheel to 1 transmission/motor?
~Silas C. F. Fischer
Unread 14-02-2008, 15:15
The Driver
AKA: Silas Fischer
Team Role: Driver
Re: Dewalt Transmission Crisis!
And... if it's easier/ quicker to explain on the phone, (603)831-0447 will get me.
Unread 14-02-2008, 15:20
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Check to see if you have your brakes on the victor........not sure if this would cause the problem, but its a good idea to remove them for drivetrains.
I believe no jumper on the brake means no braking feature.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 14-02-2008, 15:36
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by BurnFischer View Post
.... When we run the 2 motors out of the same Victor, they are syncrod close enough that the wheels run, but when we stop it seems to lock up. Is there any way we can keep them being driven on through 1 chain, or should we split it and chain 1 wheel to 1 transmission/motor?
1) Do not drive two motors from one Victor, it is specifically against the rules.
<R62> All electrical loads (motors, actuators, compressors) must be controlled by relay or PWM
output signals sent by the Robot Controller to an appropriate power regulating device
 Each CIM motor and Fisher-Price motors must be connected to one Victor speed
controller.
2)You may drive two Victors, and therefore two motors, from one PWM output by using a Y cable. Driving two wheels from one transmission is quite common as is one wheel from each transmission. You may also want to calibrate your Victors, it may help keep them in sync.
Unread 14-02-2008, 15:42
The Driver
AKA: Silas Fischer
Team Role: Driver
Driving them both from one Victor was to test whether or not it was an electrical, programming, or mechanical problem, we ruled out some stuff via running them through one victor. We already decided that once we sync the Victors they are going to just keep getting out of sync, and unless we have some way to constantly sync them... which we have yet to find a way, then syncing them doesn't work. Unfortunately... we're in a time crunch
Unread 14-02-2008, 15:55
The Driver
AKA: Silas Fischer
Team Role: Driver
We were, for the time running 2 victors off 1 PWM via y cable, but I read on another thread that it's more accurate to get them close to the same speed by calibrating it through running 1 victor per PWM
Unread 14-02-2008, 21:31
The Driver
AKA: Silas Fischer
Team Role: Driver
we fixed it.... simple fix... backdrive pins were in.....
Unread 14-02-2008, 23:30
Gboehm Gboehm is offline
FRC #1516 (Grizzlies)
Gboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to beholdGboehm is a splendid one to behold
Is this legal? and how do you do it? PM me
2005 SVR Highest Rookie Seed
2005 SVR Rookie All Star
2006 WRRF Cal Games Winner
2007 SVR Winner
2007 #7 Alliance Captains Archimedes Divison
"Any sufficiently advanced technology is indistinguishable from Magic." - Arthur C. Clarke
Unread 15-02-2008, 14:54
The Driver
AKA: Silas Fischer
Team Role: Driver
You take the Jumpers off of the Victors
Unread 15-02-2008, 15:02
The Driver
AKA: Silas Fischer
Team Role: Driver
It says nothing of the Jumpers in the rules...
Unread 15-02-2008, 15:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
There are actually two positions for the jumper; the leftmost two pins are for brake mode ("B") and the rightmost two are for coast mode ("C"). The jumper doesn't have to be removed entirely.
Unread 16-02-2008, 00:14
The Driver
AKA: Silas Fischer
Team Role: Driver
True. Although it has been determined that when removed it sets it to default; Coasting. As unnecessary as it was to remove them.... /shrug, I have no clue =P I'm tired, it's in the final hours of... lets be honest, it's in the beginning hours of completion...
Drawings/Model of DeWalt Transmission sanddrag Inventor 30 23-12-2008 19:01
DeWalt Transmission Problem Kilroy0846 Motors 4 13-02-2008 09:24
DeWalt Transmission questions StevenB Technical Discussion 22 14-02-2007 16:02
Dewalt transmission problems? roach1051 Technical Discussion 10 11-04-2006 00:33
DeWALT Transmission After Action Report CyberWolf_22 Technical Discussion 7 17-04-2005 00:28
