Go to Post Given how easily these things pop, is "Blow Out Pricing" really the best choice of words? - ahecht [more]
Unread 14-02-2008, 18:22
stuffssguy's Avatar
stuffssguy stuffssguy is offline
Team Captain
FRC #1258 (SeaLu Robotics)
stuffssguy is on a distinguished road
Looking for help with creating a timer.
We want to use a timer for executing commands. (if x button is pushed than p happens and after a certain amount of time q happens) This would most likely be for controlling the solenoids on our robot so that with one button push a piston would extend before the other. We would also use it for driving functions.
Unread 14-02-2008, 20:06
seanl's Avatar
seanl seanl is offline
"The Everything person"
FRC #0867 (Absolute Value)
seanl will become famous soon enoughseanl will become famous soon enough
Re: Looking for help with creating a timer.
you need to add a global variable at the top and if you put a counter in the while loop for autonomous you can count the iterations. this is the only way you can do it. if you put a delay in you will get the red light of death.
, Sean
TEAM 867
-electrical
-pneumatics
-programming
2008 Autodesk Visualization Grand Prize Winner
Unread 14-02-2008, 22:48
For MPLAB IFI/Watson based programming...
To use a real timer take a look at the IFI explanation in this white paper: http://www.ifirobotics.com/docs/time...004-jan-14.pdf
Kevin Watson has some examples here: http://www.kevin.org/frc/2005/
Unread 15-02-2008, 00:11
taggartbg taggartbg is offline
FRC #1712 (Dawgma)
Team Role: Electrical
taggartbg will become famous soon enoughtaggartbg will become famous soon enough
Send a message via AIM to taggartbg Send a message via MSN to taggartbg Send a message via Yahoo to taggartbg
use a "wait" function in the code
if(button){
do thing one;
Wait(3000);
do thing two;
The value inside the "wait" function is in milliseconds, so the above code would pause for 3 seconds between thing one and thing two.
Unread 15-02-2008, 00:17
For Easy C or WPILIB based programming ...
if(button){
do thing one;
Wait(3000);
do thing two;
Unread 15-02-2008, 00:54
Kevin Watson's Avatar
La Caņada High School
FRC #2429
If you're using my 2008 robot controller code, I've created drop-in replacement code for timer.c and timer.h that implements a millisecond system clock using timer 2. The code is available here: http://kevin.org/frc/ifi_clock.zip.
-Kevin
Kevin Watson
http://kevin.org
Unread 15-02-2008, 15:51
xrabohrok's Avatar
xrabohrok xrabohrok is offline
hunter of errors
FRC #1208 (The Metool Brigade)
xrabohrok is an unknown quantity at this point
the program loops at 36 times a second. With this knowledge, you could create something that would measure this. I wouldn't advise letting a counter variable get into the thousands, because then the program starts running slower. something like this worked nicely for me:
//global variables
int count = 0;
int second = 0;
//somewhere in code
if (count >= 37)
      count = 0;
count++;
//you could compare things like this
switch second
        case 0: //what happens right off the back
                  break;
        case 1: //what happens in the first second
                  break;
        case 2: //what happens in second second (ha!)
                  break;
        default: //what should happen when out of time
"It's programming's fault" may be a viable excuse for just about everything, except the robot falling apart.
It will 'cause it can!
constants aren't. variables won't.
Unread 16-02-2008, 22:09
stuffssguy's Avatar
Team Captain
The code says we are missing IFI_FRC.h
looking for help on chairman award grandmother cul Chairman's Award 19 15-02-2008 09:27
Looking for help sfshilo General Forum 3 10-04-2006 18:30
Looking for a Team to Work With KevinB Finding A Team 0 21-11-2004 14:26
Looking for contact with Millenium team. Gene F General Forum 3 09-11-2003 13:18
Looking for some help with buttons and pins... Amanda Morrison General Forum 4 26-02-2003 17:32
