Go to Post There's nothing wrong with taking suggestions but be sure not to let other people tell you how your team should be run. - NickE [more]
Unread 14-02-2008, 23:50
explodingcan's Avatar
explodingcan explodingcan is offline
Hilo Viking Robotics Webmaster
AKA: Luke
FRC #1378 (Green Label Zealots)
Team Role: Webmaster
explodingcan is an unknown quantity at this point
Resizing problem
I am using iMovie too put together my scenes from 3ds Max. how do i resize the file to the required size.
Unread 15-02-2008, 00:29
BuddyB309's Avatar
BuddyB309 BuddyB309 is offline
I freaking love animating!!
AKA: Peter Casey
FRC #1625 (Winnovation)
Team Role: Animator
BuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond reputeBuddyB309 has a reputation beyond repute
Send a message via AIM to BuddyB309
Re: Resizing problem
compressor. You need to have the NTSC quicktime format. The size needs to be 720X480.
A.K.A Llama
check out my latest animations Appliance Night Out, Infant Intolerable, Fishing Like a Loony Tune, VVV Roadside Assistance
Life? I have a life. It is sitting at my computer and Animating. AND DRAWING!!! WEEEEEEE!!!!
Unread 15-02-2008, 00:34
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Compressor is part of Final Cut Pro/Final Cut Studio, and since you're using iMovie, you probably don't have it.
Which version of iMovie?
If you have '08, you'll use the "Export to Movie" command, which is cmd-E. It's pretty self-explanatory.
I believe '06 and earlier had a "Share" command that was functionally identical to an export command. Choose QuickTime and select your options from the file save dialog's settings button.
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
iSquint and VisualHub work well.
iSquint is free, VisualHub is not.
Jacob
Resizing Camera View BrianR Programming 12 31-01-2007 16:32
G.T.S ..... (problem) Ami Schwartz Programming 3 28-01-2006 17:01
Image resizing tips? jpsaul7usa Chit-Chat 5 04-03-2005 00:52
Resizing pictures.. Brandon Martus CD Forum Support 4 26-02-2004 15:22
Resizing Assemblies in Inventor Jeff Waegelin Inventor 7 25-02-2003 13:43
