Go to Post You know this crazy ChiefDelphi... nothing but useless information and kids ranting about pizza. - Amanda Morrison [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia
  #91   Spotlight this post!
Unread 27-01-2008, 13:33
Re: Can the Plane Take-Off?
Originally Posted by lemon1324 View Post
If you theoretically create a huge fan at the end of a runway, that will shorten the ground roll of the aircraft. However, the aircraft will not have enough speed to fly if it immediately leaves this stream of moving air. Thus you can have a shorter runway but the aircraft will need to remain in the accelerated air for some time.
I dunno...on a simulator, I've been able to take off at about half the speed I'd otherwise need. I finished accelerating in the air. There are these tricks known as high-lift devices. Specifically, flaps on the wing's trailing edge. Once in the air, I'd pull them in.
Edit: Lemon1324, I know how to fly. The flaps would get retracted once I was at a decent speed, and only when I was at a flying speed. I might not even use them until I cleared the accelerated air, an then use them only until I got a better speed.
  #92   Spotlight this post!
Unread 27-01-2008, 14:02
lemon1324's Avatar
lemon1324 lemon1324 is offline
AKA: Arul S
FRC #2473 (CHS Robotics)
lemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of lightlemon1324 is a glorious beacon of light
Flaps and other high-lift devices will only make the problem worse--when you retract the flaps, your coefficient of lift drops, and so you get less lift at that particular point in the envelope. Now after you lift off (at half the ground speed, presumably) when you leave the accelerated air, the airspeed of the aircraft drops suddenly. If you also retract flaps, the aircraft will most likely stall and come crashing back down.
"I reject your reality and substitute my own"
  #93   Spotlight this post!
Unread 27-01-2008, 14:12
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
The answer is yes; the belt tracks and recreates the planes speed in the opposing direction, yet if the plane isn't moving and just standing still, then neither is the belt. The problem never states it is moving in such a speed that it would cause the plane to not move forward, it only says it would go in the opposite direction at the same speed of the airplane.
Under experiment conditions... it works perfectly fine, even at take off the belt is only moving as fast as the plane is forward, this just means the wheels are rotating at twice their normal take off speed...
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
  #94   Spotlight this post!
Unread 28-01-2008, 14:07
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
The reason I did not source the formula is because it has been around for long enough that it does not need a source. It is common knowledge. Also, the wheels can still be used to measure speed despite the fact that they are not used for propulsion. Furthermore, I am not discussing this anymore until I have seen Mythbusters. I hope that I did a reasonable job explaining some of the misinterpretations of my words. Until then, Good day.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
  #95   Spotlight this post!
Unread 28-01-2008, 14:43
I didn't ask for the source, I asked for a proof. Also, how does it tie in? You did not explain that part. The equation is there with no tie-in.
I don't disagree that the wheels can be used to measure speed, but there is a chance (I've done it in a simulator) that one or more wheels will be off the ground at any given instant, so which wheel do you measure? How do you determine which wheel's data is correct, if you do all of them?
And the conditions are clearly stated in the problem. What conditions did you have in mind? For anyone to analyze your conditions, you have to state them. You don't. Therefore, I cannot fully answer you because my mind-reader is on the blink (and has been for 19 years at this time). If I know what conditions you use, I can either agree or disagree with the conditions. I may or may not agree with you, but not knowing what conditions you have in mind prevents my doing either. I disagree based on the given conditions. You have other conditions. Very well, let's hear them.
  #96   Spotlight this post!
Unread 30-01-2008, 22:11
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
The Mythbusters have conclusively proven that a plane on a treadmill can take off! (When comparing airspeed vs. conveyor speed)
Warning! Science Content!
This can be explained by comparing the means of propulsion of a plane vs. a car. A car uses the powered spin of its wheels to propel it forward.
Now a plane uses it's propeller to push against the air, while the wheels are left to free spin. And a plane depends on the speed of the air passing over its wings to generate lift to take off. With enough headwind, a plane can take off while not moving relative to the ground. Thus, a plane will pull itself through the air, no matter if it's wheels are spinning (or how fast they are spinning) or even if they are not spinning at all.
There is a corollary to this.
And I'm not sure if I will be explaining it right.
You have to be measuring the plane's airspeed for the experiment to work. If the speed of the wheels was monitored, and you were only trying to match the speed of the conveyor belt to the rotation of the wheels, assuming no friction in the system other than that between the wheels and the conveyor, the plane wouldn't have to exert any propulsion of any kind to remain stationary (Newton's First Law of Motion). However, in real life, the plane would be pulled backwards along with the conveyor, relative to the ground due to the friction of the wheels and their bearings. So to counter this, the plane would have to be pushing some air with its propeller to remain stationary to the ground for the wheels to match the speed of the conveyor.
In this case, the plane would not take off, as the speed being measured was the speed of the wheels matching speed of the conveyor, not the airspeed vs speed of the conveyor. To sum it up, the plane would remain stationary to the ground and thus have zero airspeed (assuming no wind) and not be able to take off.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
  #97   Spotlight this post!
Unread 06-02-2008, 23:07
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Originally Posted by dlavery View Post
If you still think that the plane will not take off, then think through this: imagine exactly the same stating conditions. The airplane engines ramp up to full thrust. If you are assuming that the airplane (relative to an off-conveyor observing position) is "standing still" the explain the following: the pilot quickly retracts the landing gear, so the airplane is no longer in contact with the conveyor belt, the engines are still at full thrust, and the airplane is at zero velocity relative to the ground. What happens next? When you try to reconcile this self-conflicting condition, you will realize that in the original problem, the airplane takes off.
-dave
I will have to disagree. Engines at full power means nothing. If you retract the landing gear you will crash the plane because your air speed is 0. Many people are confusing ground speed with air speed. If air is not going over the wings you can not lift a plane off the ground plain and simple.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
  #98   Spotlight this post!
Unread 06-02-2008, 23:16
The air speed is ONLY zero if:
  1. the wind is directly from one side, or
  2. the wind is from dead aft at the same speed as the plane (and a wind that fast would ground half the planes in the area anyway).
The airplane moves forward on the ground. Ground speed is approximately airspeed, in a calm. If the aircraft is moving on the ground, it will have airspeed, unless one or both of the conditions above is met. The airplane will also be able to move fast enough to beat the wind.
Oh, and I have heard of a fighter pilot on a conventional runway who pulled his gear up to take off. No rising of the plane. If you can do the same on a moving runway, you can take off.
This besides the point that Dave was making: Same conditions apply, but the pilot simply pulls up the landing gear and is no longer in contact with the belt. IF you are assuming that the plane will stand still, THEN the plane will not take off.
However, the Mythbusters have shown that the plane CAN take off, especially because it moves, so this discussion is moot, unless you have a problem with their methods.
  #99   Spotlight this post!
Unread 06-02-2008, 23:29
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
I normally don't post in these kind of threads, yet i feel the need to in this one.
There is an airspeed/ground speed issue here.
Think about the problem in terms of the horizontal forces -- You have the thrust of the aircraft pushing the body of the plane forwards, you have the force of the treadmill being pushed opposite the engine thrust on the wheels.
F=M*A tells us that if these two forces do not equal each other, the plane will accelerate with the direction of the greater force.
As for the force being applied by the treadmill, onto the wheels -- If you think about where that force is being applied, and in what direction, you'll see that it's acting tangent to the wheel, so all (well nearly all) of that force goes into rotational motion on the wheel. I say nearly all because of any wheel bearing friction. So that force goes to almost zero.
Since there is still a force being applied to the aircraft frame by the propeller or jet engine, the plane will accelerate (f=ma)
When the plane reaches normal takeoff speed, the wheels will be spinning at twice normal takeoff speed (due to the treadmill below), but because they are free-spinning and not powered wheels, there is almost no difference between this and a normal takeoff.
my $.02
2010-? - AIR Strike (Team #78)
2007-2009- Rhode Warriors (Team #121)
2003 - Team #190
1997-2002 - Bobcat Robotics (Team #177)
http://www.tomschindler.net
http://www.drivexc.com
  #100   Spotlight this post!
Unread 11-02-2008, 15:50
296Minion's Avatar
296Minion 296Minion is offline
FRC #0296 (Northern Knights)
296Minion is an unknown quantity at this point
Send a message via MSN to 296Minion
Yes. The trust generated by the plane is no match for anything else
  #101   Spotlight this post!
Unread 14-02-2008, 23:41
Waiakea12's Avatar
Waiakea12 Waiakea12 is offline
Biohazard (Mechanical/Spirit/Scout)
FRC #2024 (Kekoa O' Haaheo (WARROR PRIDE))
Waiakea12 is an unknown quantity at this point
I think that it all depends on the size, Power, and overall weight of the plane. The "runway" size also matters.
WHAT ABOUT THE FIGHTER PLANES THAT CAN TAKE OFF AND LAND VERTICALLY AS WELL AS HORIZONTALLY? DOES THIS APPLY TO THEM??
(Don't kill each other over this one!!! lol)
P.S.- I'm a little bit late in this thread, sorry.
  #102   Spotlight this post!
Unread 15-02-2008, 01:15
Actually, plane size doesn't matter. The thrust amounts are calculated to lift each plane type. See, plane weight and size are taken into account when planning for power (thrust is the technical term on aircraft). There is always power to spare--that is, the plane will be able to take off at maximum weight, guaranteed, or the mechanic or designer is looking for a new job.
But yes, the runway size matters. The Mythbusters started with a conveyor that was too short for their R/C plane, and it went off...
And I already suggested the VTOL aircraft. That's cheating!
  #103   Spotlight this post!
Unread 19-02-2008, 19:09
BigWhiteYeti's Avatar
BigWhiteYeti BigWhiteYeti is offline
FIRST class flier
AKA: Patrick M.
FRC #0857 (Superior Roboworks)
Team Role: Driver
BigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura aboutBigWhiteYeti has a spectacular aura about
If any of you have watched Mythbusters recently, they proved it can be done! Think about it. Planes derive their power from propellers or jets, each of which move air. This forces the plane forward relative to the air, not the ground. The wheels are free-spinning, so they will move twice as fast when the plane takes off upon reaching its take-off airspeed. Airspeed and groundspeed are totally different principles.
As for the Mythbusters, they pulled a really long mat with a pickup and had an ultralite take off successfully. Look it up!
-you're fired
  #104   Spotlight this post!
Unread 18-04-2008, 21:57
wfoard's Avatar
wfoard wfoard is offline
Harbinger of breakage
FRC #0587
wfoard is an unknown quantity at this point
Red face Re: Can the Plane Take-Off?
I know that I might bnot seem reliable because this is my first post, but I wish to dispel this fear by mentioning that I have seen this done in real life, not on Mythbusters. First, the airplane did take off. For all of you people who talking about lift, yes the lift comes from the wings moving through the air. As far as the airplane moving in relation to the ground, it does. The reason for this is that the thrust comes from the engines (whether they be old-fashioned propellor or modern turbine) and has nothing to do with the wheels whatsoever. This means that basically the wheels can spin freely. Because of this, the treadmill is basically nonexistant. If you do not believe me, put a model airpland on a big treadmill and notice that it does take off. I have personally seen it done many times.
  #105   Spotlight this post!
Unread 18-04-2008, 23:36
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: stolen from another forum
Originally Posted by sanddrag View Post
As mentioned previously, a plane's flight is based on it's relation to the air, not to the ground. Thrust comes from engines pushing on the air, not from wheels pushing on the runway.
Yes but... the thrust from the prop pulls the plane forward so air rushes over the wings to produce lift.
Would the prop-wash alone be enough to produce the required air moving over the wings flight surface in order to produce the lift needed?
If the plane is on a belt moving under it at the same speed as the plane then the air above and under the wing would depend on the prop wash.
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
air speed sensor for rc plane Greg Needel Technical Discussion 19 07-10-2005 23:43
Breaking the plane kevinw Rules/Strategy 16 28-03-2005 11:06
pic: It's a bird.. It's a plane.. It's the 573 Mech Warrior bot! Lisa Perez Robot Showcase 3 27-02-2005 15:09
NASCAR, Hendrick owned plane crashed Bcahn836 Chit-Chat 12 06-11-2004 08:59
