Uneven motors
After testing our drive train, I seem to have an issue with undistributed motors, how would I go about setting a particular voltage to each motor in easyc? We tryed using the gyro, but unfortunately, this tended to be too sensitive.
Re: Uneven motors
I highly recommend using the on-line window and recalibrating your Victors. We have found them to be way off the 127 center value. After calibration they were within +/- 1.
Using the gyro you can increase the deadband or you can reduce the output by dividing by a number. gyro = GetGyro (1); gyro_out = gyro / 2; Last edited by Kingofl337 : 15-02-2008 at 13:39. |
| Motors, Motors, and More Motors | 1033missions | Motors | 1 | 09-02-2006 18:46 |
| UnEven Floor??? | sgsdragons | Technical Discussion | 18 | 23-01-2006 18:52 |
| Motors.. and more motors.. How many on your 2004 bot? | OneAngryDaisy | Motors | 33 | 23-02-2004 00:46 |
| Uneven Thrust Loads on Needle Roller Bearings | Madison | Technical Discussion | 7 | 07-02-2004 01:00 |
| Matching Drill Motors and Fischer-Price Motors | archiver | 2001 | 5 | 24-06-2002 00:51 |
