Go to Post All hail the amazing duct tape and the mighty zip-tie!!! :] - Gabe [more]
Unread 15-02-2008, 10:19
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
working pressure via 3/4 bore piston
I am curious, although the rules do not come out directly and state it, but is it legal to run a 3/4" bore piston at 60 psi? or does it need to be regulated to 30 psi?
Thanks!
Eat, Sleep, Build Robots
Unread 15-02-2008, 10:20
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: working pressure via 3/4 bore piston
Thanks!
It's perfectly leagal to to run at 60 psi.
Unread 15-02-2008, 10:42
Alex698's Avatar
Sparky
Thank you!
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Working pressure problem Armando Gonzalez Pneumatics 1 14-02-2008 09:42
24" Stroke 1.0625" Bore Piston Legality Yan Wang Pneumatics 4 05-02-2005 09:32
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
2" Bore Piston Threads Madison Technical Discussion 7 29-01-2002 22:35
