Go to Post One of the big things in FIRST is going global. - JosephC [more]
Unread 15-02-2008, 15:37
sparrowkc sparrowkc is offline
AKA: Mark
FRC #1986 (Team Titanium)
sparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to beholdsparrowkc is a splendid one to behold
Figure out what's wrong with the IR board
Our IR board has stopped working. No lights turn on when it has power and as far as I know the outputs don't work. How can I test the 5 volt regulator? Is there anything else replaceable that I could test?
Are there similar boards out there? We are really banking on antonymous, and can't afford to lose the IR
Unread 15-02-2008, 16:15
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Figure out what's wrong with the IR board
Here's the schematic if you don't already have it.
http://www.usfirst.org/uploadedFiles...0schematic.pdf
Apply power to the board and (Disconnect the outputs that go to the RC just in case) check pin 2 on J2 for 5V with a meter. If it's not there, the 5V regulator is the most likely failure.
If you're still not sure, then desolder pin 1 of the regulator, apply power and see if there is 5V on pin 1 of the regulator. This will eliminate a possible short on the board as the problem. If there's something other than the regulator I suggest trying to get a replacement from FIRST. They will probably have spares at the regional.
Good luck.
Unread 15-02-2008, 16:21
AKA: Mark
How would we get a spare at the regional? Do you mean teams would bring theirs if they weren't using it or that they will be available officially.
Unread 15-02-2008, 23:30
USUALLY, though not always, FIRST bring all the relevant spares. Extra IR, RC controllers Radios and HOPEFULLY IR boards. Otherwise you might find a team not using theirs.
I have an IRII not the FIRST version and they are very simple units. I'd really try replacing the 5V regulator.
Good luck
Steve
Unread 15-02-2008, 23:36
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
It could also be a bad pwm cables because we have had a couple bad pwm cables
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 17-02-2008, 12:29
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
See Team Update #10, there's a new issue with the IR board, which our team ironically started having just last night. See this thread as well: http://www.chiefdelphi.com/forums/sh...threadid=64285
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
What's Wrong with our Gyro??? manderson5192 Programming 4 08-02-2008 09:08
Trying to figure out the Segway... JBotAlan Chit-Chat 15 17-08-2006 19:56
how do u figure out the torque req'd to move a robot? Salik Syed Technical Discussion 11 03-11-2004 08:12
pic: What's wrong with this picture - Why were we shut off? CD47-Bot Extra Discussion 12 04-10-2004 19:16
Can't figure out auton mode TangoBravo1318 Programming 1 20-02-2003 10:06
