#16
Re: IR Board Fried?
what's the regulation regarding changing/fixing/modifying the IR board?
Are the judges going to examine the board to make sure that it's the original/approved modification? How would anyone know if I swapped the IR receiver for a stronger one to get more distance? Is that allowed? thanks |
#17
Re: IR Board Fried?
The IR Sensors themselves are not explicitly required by the rules, the rules refer only to "SIGNALING DEVICES," so you can treat the IR sensor as a custom circuit and do pretty much anything you'd like with it. Even replace it with another device that fits within the rules.
Hi, my name is Jonathan and I am from team 1660 the Harlem Knights. The same thing happened to our IR board to. But we got a solution. Our voltage regulator was reducing 9volts in to 5volts. But no signal was being sent. So we diagnosed that the voltage regulator was electricly burned. So we went online and searched for voltage regulators and we found it at www.digikey.com. We found a Regulator TO-92. The part number is 296-1365-ND.
http://search.digikey.com/scripts/Dk...keywords=78l05 If you have any questions email me at johnnyrocksursocks@gmail.com Last edited by Jonathan S : 19-01-2008 at 15:02. |
#19
Re: IR Board Fried?
Determining Why Your IR Board is DEAD
There are two main possible causes for IR board death. First and most common, you hooked up groud and v+ backwards. To confirm this apply a +12V supply to pin 1 and or 2, then ground to pin 3 and or 4. Messure the voltage at the top of capacitor 4. This should be +5v, if it is 0v then your power supply has died. You need a LM7508 5volt power reulator and replace with the one on the board. A quick fix is to use the +5volts from the RC board and hook it up to 1 and 2 then 3 and 4 to ground. Jump the connections on the power regulator (u2) on the back of the PCB. You will notice a close cluster of 3 solder point. You must jump the outer connections of the group of 3. This is how you jump the regulator. If you do this YOU MUST MAKE SURE YOU INPUT IS +5. If it is not you will kill the board. Otherwise order a replacement power reuglator for U2. If you have a +5 voltage from c4 then you must have fried the board. You need to order a new one D: Hope this Helps. |
#20
Re: IR Board Fried?
From FIRST's schematic, the part is an LM78L05, available from Digi-Key.
http://search.digikey.com/scripts/Dk...ywords=LM78l05 Any of the TO-92 package chips should work. |
#21
Re: IR Board Fried?
you can always make your own. Programing it would be a little hard without knowing the rate of the IR signal from the remote, but if you can, you can make a replacement one until you can buy another.
an example is: (MADE UP BTW) on remote, pressing play will make its IR LED pulse on,off,on,on,off (10110). If you have the replacement circuit board's IR sensor look for the IR signal pulsating at 10110, it can recognize the remote button. This isn't a complete fix, and I'm pretty sure you cannot use this in the actual match, but it's a way to practice while you don't have one. This way if you get one 3 days before ship, you're not screwed because you will have the code worked out. You'll just haveto tweak it a bit for the FIRST IR board. |
#22
Re: IR Board Fried?
We did not receive one in December when everyone else did, due to a mailing problem in our building, so we emailed FIRST and they said that we would have to buy a new one from IFI. We called IFI and placed an order for it about 2 weeks ago and got it in about 3 days.
#23
Re: IR Board Fried?
There is an IR Receiver Breakout board available from SparkFun Electronics, all you would have to do is hook it up to a digital in on the main controller and program in the stream of bits. It would make the process a lot easer.
Board: http://www.sparkfun.com/commerce/pro...ducts_id=8554# I will post some example code later once I get mine setup. Erica Young |
#24
Re: IR Board Fried?
sorry for the harmless bump, if anyone has some sample code for the sparkfun IR Reciever Breakout board then it would be welcome =D.
| fried light | Robo_Coyote | General Forum | 8 | 21-02-2007 23:04 |
| Fried chicklet | karin l. | Control System | 5 | 24-01-2007 00:07 |
| Fried Cam? | Denz | Programming | 5 | 01-02-2006 21:43 |
| We fried an 884 | Andrew | Electrical | 13 | 17-08-2003 23:02 |
| fried | archiver | 2000 | 4 | 23-06-2002 22:45 |
