Re: Kevin Watson's gyro code isn't compling
We are pretty sure the problem you stated is our problem, except the other way. We found that we are using C18 v3.15. We are currently searching for our MPLAB CD to install v2.4, and update to 3.1.
Thank you for your response. |
| Help with Kevin Watson's 2008 code | 2526 | Programming | 6 | 05-02-2008 16:53 |
| Kevin watson's sensor code | DustinB_3 | Programming | 3 | 30-01-2008 21:07 |
| Problem compiling Kevin Watson's code | Spencer E. | Programming | 2 | 07-01-2008 00:34 |
| Kevin Watson's encoder code with RPM output | MaxM | Programming | 2 | 05-02-2005 00:06 |
| Kevin Watson's Kick-off Demo Code! | Mr. Lim | Programming | 27 | 22-01-2005 03:38 |
