Go to Post what the HECK are you guys using there?!?!?! - dodar [more]
Unread 15-02-2008, 18:27
greatman05 greatman05 is offline
AKA: Chavez Clemons Jr.
FRC #2224 (Phoenix Phenoms)
greatman05 is an unknown quantity at this point
Send a message via AIM to greatman05 Send a message via MSN to greatman05 Send a message via Yahoo to greatman05
This code will NOT compile
Hello. We're having a problem...The compiler won't compile this, and we don't know why...Is there anything wrong? It seems syntactically correct...
Unread 15-02-2008, 18:43
Re: This code will NOT compile
int cube (p1_y);
return p1_y * p1_y * p1_y
int cube2 (p2_y);
return p2_y * p2_y * p2_y
int square (p1_y);
return p1_y * p1_y
int square2 (p2_y);
return p2_y * p2_y
You are declaring these functions inside the default_routine function. They should be outside any functions.
Unread 15-02-2008, 19:03
We didi put it outside any functions...at the top of the "user routines" file, and it still wouldn't be compile...Where should the declarations of functions and any user code we need go?
Unread 15-02-2008, 19:49
I noticed a few more errors in your functions.
int square2 (p2_y);
return p2_y * p2_y
If you want it to take a variable you pass, you need to declare the type of variable. Also, you shouldn't have a semicolon on the end of the declaration but should on the return statement. p2_y is a global variable, so it's not wise to also use it as a local variable (I don't think it will cause a compile error, but it is confusing to read).
If you want separate functions for each joystick axis, you could write it like:
int square2 ()
return (p2_y * p2_y);
For a generic function, you could write
int square2 (int variable_to_square)
return (variable_to_square * variable_to_square);
Note: It's much easier to help if you tell us what the error message is and what code is causing it.
Unread 15-02-2008, 19:59
OK...Thanks! It basically was a syntax error, and everytime we got something to work, it had a syntax error with the "{" and/or the "}"...the file was the user_routines.c file, where I thought you were supposed to put user code...
Unread 15-02-2008, 20:27
dcbrown dcbrown is offline
AKA: Bud
dcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud ofdcbrown has much to be proud of
int cube1 (unsigned char p1_y)
return((int)p1_y * (int)p1_y * (int)p1_y);
and you'll need to use casts to up the unsigned char to ints. Also, you can't use p1_y as a passed argument - its defined in ifi_aliases.h:
ifi_aliases.h:30: #define p1_y        rxdata.oi_analog01
and unless you are absolutely certain of the precedence rules for applying operations - use parentheses to eliminate any questions:
pwm01 = cube()  - (3 * square() ) + (5 * p1_y);  /*x^3-3x^2+5x* A cubic function to regulate the sensitivity of the robot's drive*/
  pwm02 = cube2() - (3 * square2()) + (5 * p2_y); /*same thing, son*/
Unread 16-02-2008, 16:07
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Actually you're missing semi colons everywhere.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Default code will not compile bronxbomber92 Programming 7 18-01-2008 18:44
Does anyone else think this game will not be as good as I imagine it might be? NeedMoreEngines FRC Game Design 76 15-01-2006 21:15
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
