Go to Post If anybody ever uses a terabyte in the next few years the world would probably come to an end - spadercool [more]
Unread 12-02-2008, 15:08
BeyondRamo's Avatar
BeyondRamo BeyondRamo is offline
AKA: Omar
FRC #0334 (Tech Engineers)
Team Role: Electrical
BeyondRamo is an unknown quantity at this point
Post Flag height questionable
In the manual it states in rule <R17>
"The flag holder must be permanently mounted to the ROBOT such that when the ROBOT is in any PLAYING CONFIGURATION and the FLAG is in the flag holder, the FLAG is approximately vertical and the top of the FLAG is 75 inches above the floor." Yet at the same time the ball when it is resting in the OVERPASS is approximately 6 feet or 72 inches above the floor. Hmm.... does anyone happen to see a problem there. Not only that but also the OVERPASS itself is only 6.5 feet or 78 inches above the floor, leaving very little leeway for the flag in order for it to successfully pass underneath without becoming damaged. Perhaps someone could inquire about this whole situation and see if there need to be any changes made in the manual regarding the flag and its holder.
Unread 12-02-2008, 15:46
Re: Flag height questionable
Originally Posted by BeyondRamo View Post
[...] Not only that but also the OVERPASS itself is only 6.5 feet or 78 inches above the floor, leaving very little leeway for the flag in order for it to successfully pass underneath without becoming damaged. Perhaps someone could inquire about this whole situation and see if there need to be any changes made in the manual regarding the flag and its holder.
I'm going to go out on a limb and say that there won't be any changes. Remember, the lap counter goes on the flag at the base of the holder, and I'm willing to bet that the range of the IR is limited. While there may be interference, I would say it's part of the game challenge. Also, the flag is on a flexible rod, allowing it to bend out of the way.
Unread 12-02-2008, 15:54
in between teams
AKA: Luke Van Oort
I don't see why they don't just make the flag's pole shorter. The lap counter is on the stopper, if I remember correctly, so it would be unaffected, and the modification would keep flags from impacting the bottoms of balls they pass under.
Team 1219: 2009 - Mentor
Unread 12-02-2008, 16:07
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Somebody at FIRST needs several hundred broken sticks, and they figured it would be a lot easier to outsource the labor.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 13-02-2008, 11:14
Ziaholic's Avatar
Ziaholic Ziaholic is offline
Elec/SW Mentor
AKA: Marc
FRC #1164 (Project NEO)
Ziaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the roughZiaholic is a jewel in the rough
What I don't like about <R17> is mostly semantic ...
Approximately Vertical is an arbitrary measurement. And the 75" has no tolerance specified.
In our case, we were planning on mounting our flag to our Mast ... the 60" vertical struts coming up from our drive chassis. Problem is, our Mast can tilt from vertical to 20-degree's or so ... changing the orientation of our flag.
Some judges might call that "approximately vertical" while others might not.
... and if we're 75" tall in one configuration, we won't be in the other.
... and I'd wager a paycheck that nobody can comply with 75.000000000000" tall
We may have to reconsider our flag placement, unless we can get this one reworded.
There are 10 types of people. Those who understand binary, and those that do not.
Team #1164 - Project NEO Robotics
Unread 13-02-2008, 11:23
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
75" has an implied tolerance of +/- 1/2", as I understand how numbers work....
It should be fun to see how this all works out, but my guess is that the flagpole is strong and flexible enough to not have any problems even if it does hit the trackball. As long as it has the required 0.25" radius on the end, that is...and your flagholder is mounted quite securely.
Unread 13-02-2008, 11:26
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
THe lap counter has to be at 52",51" holder plus 1" stopper, minimum in order to read correctly. We have a mentor who is an FTA for FIRST and he was at NH for the kickoff.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 13-02-2008, 11:37
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
The most recent update to the Inspection Checklist:
"Bicycle Flag: Must have an appropriate holder with correct installed height - 75” +/- 1”. The flag needs to remain approximately vertical."
This must be held when in your playing configuration. Not necessarily your starting configuration.
Ziaholic, I have not done the math, however, depending on where your Mast rotates, the top of flag will probably not be within 74"-76", let alone approximately vertical, when you tilt to 20 degreees. I would suggest finding an alternate location for your flag holder. There are several other posts/threads that talk about teams having difficulties placing their flag holder on the robot. You are not alone. We had to build a stand off in order to keep the flag from getting in the way of the trackball.
Unread 13-02-2008, 13:07
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
An interesting issue with this: what about the balls that will be sitting on the overpass? We mounted our flagholder the other day, and at the appropriate height, the top 4" or so of the flag will hit a trackball that is sitting on the overpass. I would not be surprised to see quite a few flags broken or launched out because of this interference.
Jeff Waegelin
Unread 13-02-2008, 22:51
Hastypickle's Avatar
Hastypickle Hastypickle is offline
AKA: Nicholas
FRC #1703 (Rats)
Hastypickle is an unknown quantity at this point
We mounted our flag holder the other day and the highest point on our robot when folded is about 3.5', so the flag holder looks out of place. I wonder if they will allow us to lower the flag holder to prevent it from hitting any balls still up.
Unread 15-02-2008, 20:48
strawberymochi strawberymochi is offline
=D
AKA: Elaine Higashi
FRC #2135 (Presentation Invasion)
strawberymochi is an unknown quantity at this point
Send a message via AIM to strawberymochi
quick question
we have a pneumatic actuator that's mounted to hit the ball off the overpass. Could we attach the flag mount to that mount? or is that not allowed
Elaine Higashi
Unread 15-02-2008, 20:59
Originally Posted by strawberymochi View Post
quick question
Is the mount at the right height? Is it fixed (reasonably) in position? If the answer to both is "yes", you should be able to.
Unread 15-02-2008, 21:40
GaryVoshol's Avatar
Cogito ergo arbitro
quick question
One other consideration - is the half-circle clear zone available there?
(since 2004)
Unread 15-02-2008, 23:01
Clourchn07's Avatar
Clourchn07 Clourchn07 is offline
Alumni and Mentor, Mechanical Eng
AKA: Christian .N. Clour
FRC #3634 (Hard Botties)
Clourchn07 is an unknown quantity at this point
the inspection sheet at the back of your manual states that the flag height is 75" with +/- 5".
We were wondering until we saw that ,too.
Unread 15-02-2008, 23:14
Check the revision on that. Rev E says that it is +/- 1".
Flag, Flag Holder vs Trackballs Swampdude Rules/Strategy 29 09-03-2008 09:17
Flag 1337pcgamer Rules/Strategy 3 20-02-2006 12:08
Flag Burners Karthik Chit-Chat 21 12-02-2006 19:16
'tracking' flag zdeswarte Programming 3 20-02-2005 13:53
Flag problem archiver 1999 2 23-06-2002 21:57
