Go to Post There can never be enough help, unless there's too much help. - Joshua May [more]
  #31   Spotlight this post!
Unread 15-02-2008, 15:39
Racer26 Racer26 is offline
Re: 2 batteries
Blasphemy! Everyone knows Mountain Dew is roboteer fuel.
  #32   Spotlight this post!
Unread 15-02-2008, 15:47
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: 2 batteries
You need to go back and put some more stuff on. Your robot obviously doesn't have enough functionality.
We're 15 lbs under. We must be wayyyyy lacking in functionality....
Jeff Waegelin
  #33   Spotlight this post!
Unread 15-02-2008, 20:48
GaryVoshol's Avatar
Cogito ergo arbitro
Re: 2 batteries
Add a couple of cases of Mt Dew (or Dr Pepper if you can stand that vile stuff - reminds me of cough medicine).
(since 2004)
  #34   Spotlight this post!
Unread 15-02-2008, 23:31
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: 2 batteries
I'ts actually carbonated prune juice.
  #35   Spotlight this post!
Daniel Bathgate's Avatar
Daniel Bathgate Daniel Bathgate is offline
AKA: blacklint
Daniel Bathgate will become famous soon enough
Send a message via AIM to Daniel Bathgate
Re: 2 batteries
And if I remember correctly (and our scale is working properly), we're about 80 pounds with the battery and bumpers...
And Al, thanks for the idea of painting the lead. We're about to cut some lead ballast for our robot, and I was quite concerned about the inspectors deeming it a hazardous material unlike our anything goes mentor. Paint (hopefully not lead based!) sounds like an ideal solution.
  #36   Spotlight this post!
Unread 15-02-2008, 23:48
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: 2 batteries
Back in the days when we were adding lead ballast to our robots, we used to coat the lead brick with liquid plastic tool-dip from the hardware store. It makes a very nice, tough coating that completely traps any stray particles. It stands up to a reasonable amount of abuse, and if you need to later it is relatively easy to peel it off.
-dave
  #37   Spotlight this post!
Unread 16-02-2008, 12:31
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Re: 2 batteries
Okay, easiest way to add weight is to zip-tie boxes of bolts onto the robot. They even come conveniently with a handle...
On a second note... make sure you seal them tightly...
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
  #38   Spotlight this post!
Unread 18-02-2008, 13:11
Re: 2 batteries
-dave
I agree, and it also adds a nice non slip surface.
  #39   Spotlight this post!
Unread 18-02-2008, 15:58
AKA: blacklint
Re: 2 batteries
-dave
We found some spray on rubber coating at OSH that seems to have done the trick quite nicely.
Batteries Mike Martus General Forum 26 19-02-2007 12:47
MK Batteries Mike Martus Electrical 0 11-01-2007 10:09
Batteries Der Sichelmann Electrical 18 22-02-2005 22:17
Batteries MechaJagEric Electrical 9 21-02-2003 12:48
Batteries MechaJagEric General Forum 2 27-01-2003 21:18
