Go to Post Robotics season has monopolized my time for the past several weeks so I have not been keeping up with Segway news lately - Stu Bloom [more]
Unread 13-02-2008, 10:45
tbd tbd is offline
FRC #1577
tbd is on a distinguished road
Regarding end game rules
can we, at the end of the match, after putting the trackball on the overpass and protecting it there (assuming the robot is at 2.5 meters height) till the power is off, turn the robot on just to get our mechanism down so we don't have to carry it out of the field when its at full height?
Thanks in Advance
Steampunk 1577
Unread 13-02-2008, 10:50
Re: Regarding end game rules
Thanks in Advance
Steampunk 1577
Unless you have a lot of speed at tethering up, you will have to pull it down by hand, or get the robot off the field first. (Section 9)
Unread 13-02-2008, 12:30
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
No. Unless you have a lot of speed at tethering up, you will have to pull it down by hand, or get the robot off the field first. (Sections 7, 8, and 9 imply this, I just forget which of the three outright states it--I think 7.)
Not so fast there. A blanket statement of "no you can't do this" is incorrect.
Refer to Rule <T13>. At the discretion of the head ref or field manager, you can indeed power up your Robot to position it for safe/easy removal from the field. It must be done in a timely manner, using only on-board power, and not cause a delay of the field reset.
Unread 13-02-2008, 12:44
Dave, I did clarify that you would need to be quick on the tether, did I not? (timely manner) (Also, editing now.)
Unread 13-02-2008, 15:58
tbd tbd is offline
FRC #1577
Thanks for the Quick Replays.
In addition i would like to ask if we can use Switches instead of tethering in order to get it down based on robot battery?
Thanks in Advanced
Steampunk 1577
Unread 13-02-2008, 16:51
Racer26 Racer26 is offline
In theory, you could, but you would still have to tether the controller, as the RC wont run if it can't see an OI, unless its team number is set to 0.
It will just sit there in disabled mode. Its a safety feature, sort of, I think.
Unread 13-02-2008, 17:05
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
One thing 648 did last year to lower our boom was to modify one of the wheel chair wheels to fit on the shaft of our boom motor. We used a FP to drive the arm, and extended the half inch shaft out the back of the stock gearbox. the wheel had a little hub which we slipped over the shaft, and turned the wheel to lower the boom. Our coach had the wheel on a lanyard and it was always in his posession. We also added a spring to push the wheel off once it was let go of so it was not forgotten on the robot.
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 16-02-2008, 00:37
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
If you're talking about using a switch to connect the motor straight to the battery and bypass all of the other circuitry, this is most definitely not allowed.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 22-02-2008, 11:28
Yes, my understanding was that you meant use the rc_dig_in switches, to which the answer is sure, you can, but you still have to tether it.
Unread 22-02-2008, 13:33
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
last year we had a similar problem, so we had a deprecated OI with just the controller and a single joystick glued to eachother... it worked fine.
We also learned that we can successfully backdrive our wormgear motor, so if you are in a similar situation, give the arm a wiggle and then it will move with ease.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 22-02-2008, 13:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
To aid in the whole "timely manner" bit, don't bury the tether port inside the robot where it's going to be difficult to reach. Either place the RC in an accessible location, or solder up a small extension cable for the tether port. Semi-permanently attach one end to your RC, and put the other end somewhere near the perimeter of your robot. I'm not entirely certain which pins are important and which aren't, so your best best is to wire up all 9 pins 1 to 1, 2 to 2, etc. And use a decent wire gauge since it IS carrying power for the OI. Alternatively, you could simply use an extra black programming cable or get the shortest db9/serial, male-female, straight thru cable you can find at your local Electro-Fry's CompuShack Depot.
Rules question about end of match reconfig Bruceb Rules/Strategy 6 31-01-2008 10:11
End Game Rules Nappster16 Rules/Strategy 2 17-02-2007 11:59
Questions Regarding Rules compasswilting Rules/Strategy 6 13-01-2007 14:56
Rules regarding sensors/processors phrontist General Forum 11 09-03-2004 22:38
