Go to Post Competing at multiple regionals or Championship events has no bearing on the life lessons you will learn or the unbelievable memories you will have--for that is what FIRST is truly all about. - Alivia [more]
Unread 15-02-2008, 20:37
Spiders Spiders is offline
Rookie Team
FRC #2599 (Full Throttle)
Spiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to all
Send a message via MSN to Spiders Send a message via Yahoo to Spiders
victor polarity
back in week five.. when we FINALLY got our drive chain done and aligned and working, one was going backwards when you pressed forward on the joystick, in order to fix it, it was suggested to switch the polarity of the engines on the victors, it works now but i have three questions, first, will this pass inspection? second, is this bad for the motor, and third, if any of these answers are #1no, or #2yes, how can we fix it?
Unread 15-02-2008, 20:57
Re: victor polarity
The answer to the first one is yes, the second one is no.
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: victor polarity
Swapping the polarity of the motors into the victor is fine. It is a real easy way to get the direction of your motors right without doing any software at all. It can be used by teams that use the default code and don't want to do software work.
Yes it will pass.
No it isn't bad. In fact the victors perform this reversal internally in order to reverse the direction of the motor.
No fix needed.
Ed Barker
Unread 16-02-2008, 02:46
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
Re: victor polarity
To clarify: It is fine to switch the M+ and M- leads going to the motor.
The V+ and V- leads, however, cannot be switched, for this will break your Victor in a hurry.
Team 1816 - The Green Machine
Ni Cad 7.2 polarity reversal warning! idahorobot Electrical 1 15-01-2007 16:10
Lego RCX Polarity Question SteveO Lego Mindstorm Discussion 1 08-02-2006 02:31
CIM Motor polarity question. Lightposter Motors 4 07-02-2006 12:03
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
Navigate.c Current Sense code=only one polarity Dale(294engr] General Forum 1 05-02-2004 16:25
