Code Error Light..
... Hi guys. Lately after running the robot for around 20 seconds, the robot switches to program state and the red "Code Error" light comes up.
At first we thought it was the radio, or extranneous code, but I don't think that's it, and I'm at a loss to what it could be. Our backup battery light is red, and no matter how many batteries we charge and plug in it's still red... Hmph. I don't understand, and any help would be appreciated. |
Re: Code Error Light..
When this happens, does your OI show a main battery voltage of 8.2 or 8.3?
Hopefully that helps. |
We have been getting this a lot recently as well. What I found to be a problem was a few lines that revolved around a timer using interrupts. If you have anything like that delete it and try again. Also if there is anything that the robot controller will not be able to do (i.e. divide by zero, use any kind of registry code such as windows clock, etc). If none of that is the problem then I am not sure and wish you the best of luck.
As for the other suggestions, I'll try them in the morning, thanks =) |
http://www.chiefdelphi.com/forums/sh...ad.php?t=44954 |
#7
=/ oye.
thanks, I had read about that before but had forgotten about it until now... Time to do some debugging! ;P *sigh* |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 12-10-2007 21:59 |
| Coder Error Light | paulcd2000 | Programming | 7 | 10-02-2007 15:52 |
| GTS Code Error (the red light of doom!) | Denz | Programming | 9 | 07-04-2006 17:39 |
| Code error on RC after downloading "bells and whistles" version of Kevins camera code | DanDon | Programming | 6 | 10-01-2006 18:07 |
| C++ Code Error? | Adam Shapiro | Programming | 9 | 20-01-2003 13:24 |
