Go to Post The game is as much a competition of strategies as it is of robots. There is never any one "best strategy." If teams choose to use this as their strategy, find one that will beat them. - srjjs [more]
Unread 15-02-2008, 19:37
Drakan290 Drakan290 is offline
FRC #0116
Drakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to beholdDrakan290 is a splendid one to behold
Making wires in Inventor! [High Res]
I've compiled a short tutorial on how to create wires in inventor...
I'm going to upload one with photos integrated into it in a few minutes.
This is how I've figured it out, so if there are more efficient ways to do this, please voice the thought in here.
This is really basic, so be warned; I probably can't answer any heavy questions.
Start out with an assembly. If you're doing the Controls Box, like I am, the easiest way to connect multiple components together is in assembly mode.
Now, go to the part that you want to start the wire on, right click it, and edit. You have to go down to the PART level of editing to get this to work right.
http://i179.photobucket.com/albums/w...rial/Step1.jpg
Now that you're at the part level, you have to go and harness the part to make the pins. Go up to the top menu (Assembly Menu) and change it to Harness part.
http://i179.photobucket.com/albums/w...rial/Step2.jpg
You should see a screen that looks like this:
http://i179.photobucket.com/albums/w...rial/Step3.jpg
Next, click on the Create Pin button, and if you're working with a circular connector (Sure hope so!) make it a concentric pin.
http://i179.photobucket.com/albums/w...rial/Step4.jpg
There should be a little yellow pin show up, and you can name it to whatever convention suits you. For tutorial purposes, I'm calling it Connector 1.
http://i179.photobucket.com/albums/w...rial/Step5.jpg
Now, if your assembly is using the same part for all it's connections (Like mine is), all of your connections will have a pin on them. Inventor makes it easy!
http://i179.photobucket.com/albums/w...rial/Step6.jpg
Now that you've created your pins, you should finish the edit (Right click, Finish edit, Finish Edit). I'm going to use two of the Circuit breakers and connect them together for this tutorial. Notice how both of them have pins on all of the screws.
http://i179.photobucket.com/albums/w...rial/Step7.jpg
For the next step, go back to the Assembly panel, scroll down until you get to the Create Harness button. Create a harness, and use the default name. You'll rename it later on.
http://i179.photobucket.com/albums/w...rial/Step8.jpg
Now, you should come to a screen that has Create Wire/Cable, Segment and other confusing items in the left tray. It's not hard to figure them out though, they're pretty generic. Now, go to create wire, and this is where you get to use pins.
http://i179.photobucket.com/albums/w...rial/Step9.jpg
Now, you need to figure out which type of wire you want to use. For this demonstration, I am going to use 12 guage RED wire. Go to Generic under the category, and 12AWG-RED for Red 12 Guage wire.
http://i179.photobucket.com/albums/w...ial/Step10.jpg
Now, select the second pin, click it, and hit apply.
http://i179.photobucket.com/albums/w...ial/Step11.jpg
Now, click on Create Segment. This is basically determining the routing of a wire.
http://i179.photobucket.com/albums/w...ial/Step12.jpg
Pick some points to place the segment points, preferably easy to access, as you will most likely be routing the wires through space. When you're done putting points in easy to access space, hit apply and finish the segment. You'll need to use 3d Move in this tutorial.
http://i179.photobucket.com/albums/w...ial/Step13.jpg
Now, you're going to have to move the segment. Go to the point you want to move, and right click it, and hit 3d Move/Rotate. Move it to the right area, and then do that to all the other points. Make sure that you're not making the points too close, or you'll get a Geometry error. To fix it, just 3d move the points so the angle is not as strict.
http://i179.photobucket.com/albums/w...ial/Step14.jpg
http://i179.photobucket.com/albums/w...ial/Step15.jpg
Now that you've moved all the points to the space in 3d world that you want, it should look something like this:
http://i179.photobucket.com/albums/w...ial/Step16.jpg
Now, you're going to have to route the wire through the segment. You're going to want to do a single segment for the purposes of this tutorial, so click on single segment.
http://i179.photobucket.com/albums/w...ial/Step17.jpg
Ok, so now that you're at the screen to connect the segment, you're lost. OK don't worry, you're still on track. Now, click on the red arrow that says Wires, and select the wire we put in earlier.
http://i179.photobucket.com/albums/w...ial/Step18.jpg
Now that you've highlighted the wire, then highlight the segment you created earlier. Click on apply, and you should get something that looks like this:
http://i179.photobucket.com/albums/w...ial/Step19.jpg
Ok, so you've got to now go and right click the wire, and select Display as Rendered. It should show up as a 12 guage red wire.
http://i179.photobucket.com/albums/w...ial/Step20.jpg
Exactly what we want; except the segment we created is still blue... To fix that, we right click on the segment, and go to Harness Properties.
Go to the tab that says Display. Uncheck the "From Loom" option. There should be a drop down menu, and you should select Red from here.
http://i179.photobucket.com/albums/w...ial/Step21.jpg
Hit apply, and OK, then you should have a fully wired pin to pin!
This can be applied to anything, the sky is literally the limit on this project, as you can even attach wires to stuff such as brick walls... However strange that is.
Anyway, after figuring this out through trial and error, I'm sure that there's multiple ways to do this, probably more efficently than how I did it, but it's perfect for a starting guide.
This is what I've been able to accomplish in the last few hours of meeting time, hope you guys have been able to get a sense of accomplishment out of this.
-Brett Buchanan
P.S. I've attached the files for download in a ZIP file. The Final is the completed edition.
PSS Edit: All the pictures are in order in a ZIP file also.
http://thebrokegamer.com/images/Inve...orial_Pics.zip
http://thebrokegamer.com/images/Breaker.zip
Unread 15-02-2008, 19:49
Logan's Avatar
Logan Logan is offline
Inventor Zombie
FRC #0103 (Cybersonics)
Logan is on a distinguished road
Re: Making wires in Inventor! [High Res]
Unregistered version of inventor. Is there any difference from the registered one or is it like a trial?
Unread 15-02-2008, 19:50
FRC #0116
I just haven't activated it, because I'm using it on my HomePC and we don't have enough lisences. I can use a trial for 30 days, so I'm using it until season is over, then uninstalling it. It makes no difference to the parts though.
Unread 16-02-2008, 09:45
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Originally Posted by Drakan290 View Post
...we don't have enough lisences. I can use a trial for 30 days
Students can download Autodesk Inventor 2008 Professional for free from http://engineersrule.org and register to use for 14 months. And by the time that license runs out the next release should be posted.
There is also information on routing wires in the Help>Skill Builders and additional information in a Routed Systems Getting Started pdf document on you hard drive in the Inventor directory. And there is curriculum material at the http://engineersrule.org site.
You might also check pg 16 & 17 in this document for technique to get wires to look more realistic
http://home.pct.edu/~jmather/AU2007/...7;20Mather.pdf
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 17-02-2008, 13:32
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
Hey, this is a great tutorial. However, I can figure out how to remove the visibility of the pins. Can you help me with this?
thanks.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 17-02-2008, 16:12
MGoelz's Avatar
MGoelz MGoelz is offline
Miranda: Design and Scouting
FRC #0234 (Cyber Blue)
MGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond reputeMGoelz has a reputation beyond repute
Send a message via AIM to MGoelz Send a message via Yahoo to MGoelz
To remove the visibility of the pins you have to edit the part that you put them on and then remove the visibility by right clicking.
If that doesn't make sense or doesn't work, just PM me. I would be glad to help in any way I possibly can.
"The ideal engineer is a composite ... He is not a scientist, he is not a mathematician, he is not a sociologist or a writer; but he may use the knowledge and techniques of any or all of these disciplines in solving engineering problems."
— N. W. Dougherty
Unread 24-02-2008, 19:08
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
sweet, that totally helped!
Unread 24-02-2008, 20:00
Ross340 Ross340 is offline
It's all food in the food
AKA: Ross
FRC #0340 (G.R.R.)
Team Role: Driver
Ross340 will become famous soon enoughRoss340 will become famous soon enough
Not to get off topic, but do you have windows blinds or something? That's a sweet theme.
Unread 04-03-2008, 14:59
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
I can say from experience in Inventor Pro10, that if you have some wires made that way that are intersecting, you can very easily change that by locking down some of the points, adding a new one, and free-moving it to wherever you want. I don't know exactly how well this would work in 2008, since I haven't been able to use it, but good luck.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 19-03-2008, 10:31
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
Im trying to do the 6 gauge wiring on the battery and I can't find 6gauge in inventor from the list...it goes down to 8 gauge, but 6 gauge is no where to be found...hmmm
Unread 25-03-2008, 02:01
Chris Herold's Avatar
Chris Herold Chris Herold is offline
Autodesk Inventor Guy
FRC #1983 (Skunkworks Robotics)
Team Role: Student
Chris Herold has a spectacular aura aboutChris Herold has a spectacular aura aboutChris Herold has a spectacular aura about
Send a message via ICQ to Chris Herold Send a message via AIM to Chris Herold
I might be a little late but I hope I can help you. If you want to run a AWG 6 wire, you basically go into the library files, copy one of the AWG 8 or whatever you want and then edit it. You can build your own gauges like this! This helps also for pneumatic tubing which is easier to make than a flexible hose if you use wires...
Like I said, hope I can help
Oregon Regional, Portland: Kleiner Perkins Caufield & Byers Entrepreneurship Award; Underwriters Laboratories Industrial Safety Award; Quarterfinalist (thanks to 492, 2130)
Microsoft Seattle Regional, Tacoma: Engineering Inspiration Award; Regional Winner (thanks to 2046 and 949); Delphi “Driving Tomorrow’s Technology” Award
Autodesk Inventor Award Finalist: Finalists
Make sure to check out the finals and vote at Firstbase!
Unread 25-03-2008, 09:43
fluffy's Avatar
AKA: David
FRC #3663 (CPR)
thanks, Im still working on it, and will be submitting the drawing into a local competition in May.
Making Gears/Chain in Inventor? jimmythetulip22 Inventor 3 29-01-2008 17:55
High Res Photos: FRC, FLL, and After-Party jingman Championship Event 3 02-05-2006 19:16
Making spheres in Inventor wilshire Inventor 8 14-01-2006 23:24
Making a series of spaced holes around a cylinder in inventor James114 Inventor 13 21-11-2004 18:44
