Go to Post I'm totally hooked on reffing now and will be volunteering in the future because of [Beach Blitz]. - Ali Ahmed [more]
Unread 15-02-2008, 18:17
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Simple way to plug pressure lines?
Hi I have 4 places where I want to plug the default pressure-out port on a Festo solenoid.
I'm only using the solenoid to charge or vent one side or a cylinder, and in the normal (released) position of the festo, it's in the "vent" configuration (by design) , which means that I need to plug the #2 port to prevent losing all my air.
When I activate the solenoid, it applies pressure to the cylinder via port 4.
It seems silly, but I can't concoct an easy way to "plug" the #2 port.
The only thing I can think of (using KOP components) is to run the port to a T connector and then jumper the two other openning to themselves.
Is there a simple way I'm missing?
Phil Malone
http://www.GEARSinc.org
Unread 15-02-2008, 19:12
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Simple way to plug pressure lines?
I think you'd be hard-pressed to find an easier way to do that with stuff from the KoP. One thing worth trying is using one of the flow control elbows with the knob tightened down all the way, but I'm not certain that that will actually give you zero flow. In any case, if you want to kludge it together for now, and then make it a little more elegant at the competition, take a look at McMaster part number 51055K429.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 15-02-2008, 22:03
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
simply kink a short hose and tie it with a tie wrap and bingo.
Unread 15-02-2008, 22:30
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
You could do it with one of the brass T-, two brass plugs and a hose fitting, all from the KOP.
Unread 16-02-2008, 06:56
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
I would recommend the t-junction method over this one. It doesn't sound very reliable. It probably wouldn't impress inspectors either.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 16-02-2008, 08:40
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We got some 1/8" pipe caps (brass) at the hardware store, and screwed the straight tube to threaded adapters into them to accomplish this. The caps don't cost much and are easy to find.
As far as I can tell this is allowed by the rules.
If we have any trouble at inspection, we'll go back to the looped Ts....
Unread 16-02-2008, 10:12
IndySam's Avatar
Never had it fail or not pass inspection. I will admit the other method would be prettier.
Unread 16-02-2008, 14:08
PhilBot's Avatar
AKA: Phil Malone
Originally Posted by jgannon View Post
.One thing worth trying is using one of the flow control elbows with the knob tightened down all the way, but I'm not certain that that will actually give you zero flow.
Thanks...
Yeah, we thought of the flow controls. It turns out that these won't actually go all the way closed....
Phil.
Phil Malone
Unread 13-03-2008, 09:32
sporno's Avatar
sporno sporno is offline
AKA: David
FRC #0540 (Talon)
sporno will become famous soon enoughsporno will become famous soon enough
Send a message via AIM to sporno
My team has done the brass T fitting before , but if weight is a major major issue ( we cut 2 brass "t"s and a few plugs to drop a lil weight) you can use a plastic t fitting and use a tube from the KOP and run the tube from one end to the other end, make sure the tube is cut well when you do this.
just my $.02
2005 NASA/VCU Quarter-finalist
2006 NASA/VCU regional-Semi-finalist
2006 FIRST Robot Rumble-Quarter-finalist
2006 FIRST Robot Rumble-Most Promosing Rookie Drive team.
2006 Championship-Curie
2007 NASA/VCU- Regional Winner
2007 Championship-Galileo
2007 FIRST Robot Rumble-Semi-finalist
80+ matches on the field
Unread 13-03-2008, 22:15
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
This works great, and it's a lot lighter than using the brass fittings if it is going to be on an inspected robot.
Art Dutra IV
世上无难事,只怕有心人.
Unread 13-03-2008, 22:25
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
The fastest, lightest, and easiest way is the kinked tube, as IndySam described. Once it's folded over, and the ziptie is tightened, you will never leak air through that port again - it works great. It's also definitely legal.
Unread 13-03-2008, 22:37
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
McMaster Part # 51055K429
Moisture-Resistant Acetal Push-to-Connect Cap for 1/4" Tube OD, Gray
In stock at $1.41 Each
or search for "Push-to-Connect Tube Fitting Cap"
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 13-03-2008, 23:00
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Man, that sounds kinda familiar.
_
Unread 13-03-2008, 23:11
Engineering Mentor
FRC #0254
Sorry dude... It was kinda buried in your post. No one else really took note of that either. By far the simplest solution mentioned.
-Travis Covington
Unread 14-03-2008, 02:10
monty1540's Avatar
monty1540 monty1540 is offline
College Student Mentor
AKA: Eric
FRC #1540 (The Flaming Chickens)
monty1540 is an unknown quantity at this point
Send a message via Yahoo to monty1540
you said you're using festo valves? If my memory is correct, they have built-in push to connect fittings?
We have some plastic plugs from SMC that are designed to go into a push to connect port and plug it. They're basically a special plastic version of pneumatic tube - specifically; without the hole in the middle.
SMC Push To Connect Port Plug
[ .02 $ ] Fewer push-to-connect[ions] on the robot means less air leakage - they don't leak much, but they all do slowly leak. Connecting a hose, and then a cap, is two connections, versus a plug, which is only one. [ / .02 $ ]
-Eric
Current WPI Student and college mentor to 1540
1540:
2008 Portland Regional Winner
2008 Portland Regional Engineering Inspiration Award
2007 Pacific Northwest Regional Finalist
2007 Pacific Northwest Reigonal Chariman's Award
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
battery plug itay_ms Electrical 3 03-02-2007 21:32
cruise lines robot180 Chit-Chat 9 29-06-2004 22:03
pic: Another one from way, WAY up CD47-Bot Extra Discussion 18 01-05-2004 02:31
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
