Go to Post In any case, I'd like to remind everyone to practice gracious nonexpansionalism while in your pit. - sanddrag [more]
Unread 16-02-2008, 07:59
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Exclamation Toggle Motor On & Off Help.....
Hello, does anyone know how to program in MPLab this thing... We want pwm02 to turn on if p3_sw_trig was hit. Then, if it's hit again, to shut pwm02 off. Basically like an on or off button. Any help would be greatly appreciated. Thank You.
Unread 16-02-2008, 11:15
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Toggle Motor On & Off Help.....
This involves storing the last state of your button, something like this:
void Run_Motor_Button (void)
static unsigned char engage_motor = 0; //Should the motor be on?
static unsigned char last_button_state = 0; //This will be the last position of p3_sw_trig
if (p3_sw_trig && !last_button_state){ //The button is pushed but wasn't last time
engage_motor = !engage_motor //Change what should be happening to the motor
last_button_state = p3_sw_trig; //Update the state of the button
if (engage_motor){ //Use the motor if needed
pwm02 = 255;
} else {
pwm02 = 127;
This is a good thing to know how to do, as it is used fairly often. I advise that instead of copy/pasting the code that you read the comments and write a similar routine yourself.
Getting Gear off of Fisher Price Motor Denman625 Motors 2 12-02-2008 20:58
Off Season Software for Rack & Roll Kims Robot Off-Season Events 0 22-10-2007 14:54
2005 Off-Season Competitions; A list of what, when, & where Erin Rapacki Off-Season Events 2 25-01-2005 14:23
Novi Kick-off & Workshop Dung H Cao Thanks and/or Congrats 0 06-01-2002 09:37
