Go to Post They were designed that way so they would be compatible with the water-based ga.... oops, sorry, we aren't supposed to say anything about that. Never mind. - dlavery [more]
Unread 16-02-2008, 11:57
generalsnipe's Avatar
generalsnipe generalsnipe is offline
AKA: Michael Irvine
FRC #2136 (Team IMF (Imposible Misson Force))
generalsnipe is an unknown quantity at this point
OI COMPLETLY DEAD?
our OI controler went completly dead today i tried to see if i can reset it, but the green power light comes on, now all the lights are on , we dont know what to do, any help would be nice, and a possible error might be that the wires were put backwars in the comp port, thanks for helping in advance
Rookie here, needs some help, but im using my mind
Unread 16-02-2008, 12:03
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: OI COMPLETLY DEAD?
Have a look at IFI's tech support forum, and if that doesn't work, get in touch with an IFI tech support representative.
Maybe someone will be able to help you here in the meantime.
Unread 16-02-2008, 12:35
AKA: Michael Irvine
well i called and they are closed. but we are gonna see if we can borrow a OI from a differnt team
Unread 16-02-2008, 15:34
If you can't fix it before your regional, talk to the IFI rep first thing on Thursday. If they can't fix it, they will send you to Spare Parts to get one of their loaners. (You'll need a credit card; if you don't return it, IFI will bill the card for the cost of the interface.)
Unread 17-02-2008, 02:22
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
putting the wires in backwards to the COMP port does not fry your OI. We had a team member accidentally think pin 1 was pin 8 but it really wasn't so then it all got wired in reverse. 2 weeks later the OI is still working with out problem...
Did you buy chance try to run power through the COMP port??
If that was in reverse then yes i would say you have a dead OI
Unread 17-02-2008, 11:06
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Try to reload the master code to your RC, and tether your OI to the robot.
http://www.ifirobotics.com/docs/frc-master-ver15.zip
This may or may not be legal... but the OI from last year is identical to the one this year. Maybe hit up Q&A to see if you can use yours from last year. The main purpose of not being able to use parts from previous years is because it can give you more performance, but since nothing has changed, and it is your OI, that doesn't have any customization for it, I think they may say yes.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Dead OI Smrtman5 Control System 1 30-10-2004 00:39
dead reckoning st28 Programming 1 24-02-2004 11:34
Dead Reckoning Ryan Cumings Programming 3 24-02-2004 10:57
Dead Reckonin Hop_of_752 Programming 3 08-02-2004 19:28
