Go to Post Ya know something I heard, UFH always look beter in PINK! :) - Kyle Love [more]
Unread 15-02-2008, 19:30
dormedas dormedas is offline
FRC #2523
dormedas is an unknown quantity at this point
Code to shift with Servos
Okay, well, I'm not our team's programmer but I understand how this works and I cannot for the life of me get these servo shifters on the AM super shifter to do anything. They quite literally do nothing, no turnning or anything. I have been combing the forums for a solution but I am a bit short on time so I just figured I would post the problem. These are the new AM super shifters we are using with servos provided. The code is:
if (pl_sw_trig == 1)
pwm15 = 255
pwm16 = 255
else
pwm15 = 0
pwm16 = 0
if (pl_sw_top == 1)
pwm15 = 0
pwm16 = 0
else
pwm15 = 255
pwm16 = 255
Do you see anything wrong with what we are doing? or any other information needed to know what's wrong?
EDIT: We hooked up the servo to a standard RC controller with a servo controller... It worked perfectly.
Help?
Unread 15-02-2008, 19:40
Re: Code to shift with Servos
The code looks except for a few typos (missing semicolons, l/1, etc) which I assume is from retyping the code.
Since you are using pwm15 & 16, are you calling either IFI's generate_pwms or Kevins PWM function?
Is the backup battery plugged in and charged? The servos get power from it, so if it isn't working, your servos won't move.
Unread 15-02-2008, 19:47
FRC #2523
Yes, the semicolons are actually there. (This is the team programmer speaking)
We are using Kevin Watson's PWM call functions.
Our problem is thatvour 7.2v backup battery was not charged, we ran it off of an external source giving 7.2volts to the backup battery pins..
It worked, thanks a ton! Also: how do we recharge our 7.2v battery?
Unread 16-02-2008, 03:15
ay2b's Avatar
ay2b ay2b is offline
AKA: Andy
FRC #2928
Rookie Year: 1994
ay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant futureay2b has a brilliant future
A charger should have come in the electronics box in the kit of parts. If it didn't, or you can't find it, any hobby store and many toy stores should carry chargers for 7.2v NiCad battery packs.
2011 - SD Quarterfinalists (980), LA Quarterfinalists (980)
2010 - LA (2404) Finalists (980), AZ Motorola Quality (980)
2009 - LA Semifinalists (980); Las Vegas Quarterfinalists (980); SD (2404); IRI #1 Seed, Finalist (980)
2008 - SD Quarterfinalists (980), LA Champions (980), LA Rookie Inspiration Award (2404); CalGames Finalists
2007 - So.Cal Finalists (980), SD Quarterfinalists (980); CalGames Finalists
2006 - So.Cal Regional Champion (4), Toronto Judge's Award Day 1 (4)
2005 - SVR Champions, Delphi "Driving Tomorrow's Technology" (980); AZ Xerox Creativity (980); So.Cal Finalists, RadioShack Innovation in Control (980); Championship Archimedes Division Semifinalists; IRI Finalists (980)
2004 - So.Cal Regional Champions, Leadership in Controls (980); AZ GM Industrial Design (980); Championship Galileo Division #2 Seed; IRI Champions
2003 - PNW Semi-finalists (488)
2002 - PNW Finalists (488)
2000 - X-bot / 488 - Mentor / Founder
1994 - Sunny Delight - Driver - champion
Unread 16-02-2008, 12:27
kE7JLM's Avatar
kE7JLM kE7JLM is offline
KE7JLM `
AKA: John Harris
FRC #0842 (Falcon Robotics)
Team Role: Driver
kE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to allkE7JLM is a name known to all
Send a message via MSN to kE7JLM
Here what I used:
if(p1_sw_trig == 0)
pwm05 = pwm06 = 255;
else
pwm05 = pwm06 = 0;
Team 842 Programmer
Pictures at:
http://picasaweb.google.com/KE7JLM
http://picasaweb.google.com/john.h.842
Videos -
http://www.youtube.com/user/KE7JLM
When your not busy with FIRST try NURC
To Shift or Not To Shift, That is the Question AdamC Technical Discussion 15 08-11-2007 14:00
using servos with camera team877 Programming 2 01-02-2007 21:26
Are Spikes needed with servos? aksimhal Electrical 9 23-01-2007 20:27
To shift or not to shift? sanddrag Technical Discussion 61 15-04-2003 22:56
Can RC servos be used with EDUbot? ChrisH Technical Discussion 4 31-12-2002 01:45
