Go to Post Robotics = my anti drug. - Queen_of_Mascot [more]
Unread 02-02-2007, 14:50
Transformers Transformers is offline
FRC #2260 (Transformers)
Transformers is an unknown quantity at this point
pressure switch wiring question...
I looked through the existing threads concerning pneumatic pressure switches, but didnt see anything concerning the steps taken to wire it to the RC. Forgive me if i missed it but how are the two wires from the pressure switch connected via PWM style cables to an input on the RC? Any tips or techniques would be greatly appreciated! Thanks again.
Yes, Spanky
Unread 02-02-2007, 16:13
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: pressure switch wiring question...
Use the black and white wires on a PWM cable. Then connect it to a digital input.
Unread 03-02-2007, 16:13
Ah so do I have to take the PWM connector with 3 prongs completely off and then just use the black and whites to wire the pressure switch? Thanks.
Yes, Spanky
Unread 03-02-2007, 16:22
Electrical Engineer
Rookie Year: 1995
Yes. And be sure to insulate the red (unconnected) wire as it will have 5 volts present on it.
Mike Betts
As easy as 355/113...
Unread 03-02-2007, 22:31
An easy way to prevent the 5 volts from getting into trouble...Using a fine point wire cutter, cut the red wire next to the connector that will be plugged into the RC. If you pull on the wire ( or slip a knife blade between the wires) it will separate from the white and black wires. Pull back about 1/2-1 inch and cut off the excess length of red wire and you're done.
Unread 05-02-2007, 14:44
Alright, great thanks a ton. However, we do have to include code in our program to sense the pressure switch at all, correct? thanks again guys
Yes, Spanky
Unread 05-02-2007, 14:54
The code is embedded in the default code, copy and paste as needed and then modify if you are using a different relay output or digital input than those for which the code was written.
Unread 07-02-2007, 13:19
Ok, well one more question, is there actual default code that we can access? I thought it was just already in the RC...? I found some code that says its for the pressure switch in the actual manual, is that the one i should use? Thanks!
Yes, Spanky
Unread 07-02-2007, 13:30
The section in the default code looks like this:
  relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
  relay8_rev = 0;
It was in the Robot Controller as shipped.
The Pressure sensor connects to digital input 18, the connection to the spike handling the compressor goes on Relay 8.
Unread 07-02-2007, 14:02
Alright, it is shutting off at 115 now, thanks, i think it was that we had the inputs in the wrong spots. Thanks for the help!
Yes, Spanky
Unread 16-02-2008, 12:28
M.Jesus's Avatar
M.Jesus M.Jesus is offline
AKA: Miguel
FRC #2617 (Robo Reds)
Team Role: Electrical
M.Jesus is an unknown quantity at this point
Send a message via AIM to M.Jesus
does it matter what sides of the switch you wire the power and ground to?
m.jesus
Unread 16-02-2008, 12:55
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Nope, there is no positive and negative to the switch
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Pressure Switch Wiring idahorobot Electrical 1 27-01-2007 11:18
Pressure Switch wiring diagram robotjoe Electrical 1 08-02-2005 14:01
Pressure Switch Wiring Question Matthew_H Electrical 4 16-02-2004 01:25
Pressure Switch Wiring Question Matthew_H Control System 1 08-02-2004 15:28
Question about Pressure Switch Randy_Ai Technical Discussion 1 30-01-2002 18:29
