Go to Post Duct tape is like the Force - it has a dark side and a light side and it holds the universe together. - Jnadke [more]
Unread 16-02-2008, 15:48
Shivang1923 Shivang1923 is offline
I make robot go VROOM VROOM!
FRC #1923 (MidKnight Inventors)
Shivang1923 has a spectacular aura aboutShivang1923 has a spectacular aura about
Thumbs up Programing IR board problem
Hey. We are trying to program autonimous with IR board.
here is our code:
 //**** Check the IR Sensor for a new command
  sensorReading  = PORTJ>>4;  // Combined digital inputs 15-18
  if (latch == 1)
    if (sensorReading == 0)
      latch = 0; // Take only the 1st reading to avoid being caught by a half & half state of the IR sensor
  else if (sensorReading != 0)
       latch = 1;
       if (sensorReading == 8)      IR_cmd = 1;
       else if (sensorReading == 4) IR_cmd = 4;
       else if (sensorReading == 2) IR_cmd = 2;
       else if (sensorReading == 1) IR_cmd = 3;
        printf("IR_cmd = %d\r\n", IR_cmd);
 switch(IR_cmd)
    case 0:
  		break;
    case 1:
		if (counter <= 50)
			pwm01 = pwm02 = 255;
			counter++;
		else
			counter = 0;
			pwm01 = pwm02 = 127;
	    break;
    case 2:
       pwm01 = 200;
       pwm02 = 55;
       break;
    case 3:
        pwm01 = 55;
        pwm02 = 200;
        break;
    case 4:
        relay1_fwd = 1;
This one loops forever. The problem is the counter = 0;.
If we remove it, the motors never stop moving
We want to have it configured so if button one is pressed, it will move forward for x seconds, and so on for the rest.
another problem is that the relay will not fire.
Any help will be appreciated. Thank you.
Unread 16-02-2008, 17:25
Re: Programing IR board problem
If the relay is a single solenoid you might need to add:
relay1_rev = 0;
If it's a double solenoid then depending on how it's wired it might possibly be:
relay1_fwd = 0;
relay1_rev = 1;
How is counter initialized?
Make sure you made counter either global or static and initialized the value to zero, otherwise, counter will be zero everytime this gets executed and it will go on forever.
Resetting counter to zero will just continue the loop endlessly.
Unread 16-02-2008, 17:40
The variable is static, and initialized to zero.
static int counter = 0;
Unread 16-02-2008, 18:22
Well, the only thing I see (if the "command = 0" line is removed to prevent the endless looping) is that IR command 1 would not work properly if you ever pressed it a second time. That could be fixed a number of ways, e.g., use a toggle to reset counter=0 when the button is pushed a second time.
Unread 16-02-2008, 20:27
so i would do this?
case 1:
                counter = 0;
		if (counter <= 50)
			counter++;
		else
	    break;
Unread 16-02-2008, 22:55
Maybe something, such as,
  if (latch == 1)
       latch = 1;
if (IR_cmd == 0)
 counter = 0;  // To initialize counter whenever cmd 1 finishes executing
 switch(IR_cmd)
    case 0:
          break;
    case 1:
        if (counter <= 50)
            counter++;
        else
           IR_cmd = 0;  // So cmd 1 won't try to repeat itself
        break;
    case 2:
       pwm01 = 200;
       pwm02 = 55;
       break;
    case 3:
        pwm01 = 55;
        pwm02 = 200;
        break;
    case 4:
        relay1_fwd = 1;
IR board problem AmitCarmeli Electrical 3 09-02-2008 18:53
Another IR Board Problem C222 Electrical 2 13-01-2008 17:36
Do you have a problem with the IR Board? DonRotolo Control System 5 07-01-2008 23:57
Lights in Joystick board or control board rcubes85 Control System 15 26-02-2005 23:40
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
