Go to Post One of the big things in FIRST is going global. - JosephC [more]
Unread 16-02-2008, 15:24
Spiders Spiders is offline
Rookie Team
FRC #2599 (Full Throttle)
Spiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to allSpiders is a name known to all
Send a message via MSN to Spiders Send a message via Yahoo to Spiders
festo vavle prob
we need help getting our festo working, we have 1 on negative and 2 on positive, and the tubing is correct, the red and blue are connected to the spike, and the tubes are connected right, the flow goes through when the manual button is turned, it works, when we press the spike the light turns on but nothing happens.. what could be wrong? i know valve spelled wrong.. i was in a rush
Unread 16-02-2008, 16:08
Rookie Team
Re: festo vavle prob
doesn't anybody know?
Unread 16-02-2008, 16:12
AdamC's Avatar
AdamC AdamC is offline
Lathemeister
AKA: Batman
FRC #0395 (2Train Robotics)
AdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of lightAdamC is a glorious beacon of light
Send a message via AIM to AdamC
have you checked the solenoids? One could be burned out.
"The glass is neither half-full or half-empty. It is twice as large as it needs to be."
"Any job worth doing is a job worth dying for."
Unread 16-02-2008, 16:14
Rookie Team
im not to sure how to check if their burned out
Unread 16-02-2008, 16:27
AdamC's Avatar
Lathemeister
AKA: Batman
Replace the solenoid with a new one and see if it works. I don't know if you have any spares...
Unread 16-02-2008, 16:29
Rookie Team
dont have any spare festo, just switched to the dbl solenoid
Unread 16-02-2008, 16:36
AdamC's Avatar
Lathemeister
AKA: Batman
that works too
Unread 16-02-2008, 21:01
Racer26 Racer26 is offline
1075 uses pneumatics extensively, and we've found the plastic festo's included in the 2005-08 KOP to be rather unreliable. They tend to break and cease functioning the fastest of all the KOP valves since 2003
Unread 16-02-2008, 22:15
Jrocklz's Avatar
Jrocklz Jrocklz is offline
FRC #1341 (Knights Who Say Ni)
Jrocklz is an unknown quantity at this point
Ours didnt work either (had same problem). We ended up using the smc valves.
Unread 16-02-2008, 22:45
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
Ours didn't work (exact same thing happened), so we got a replacement. The replacement had the same exact problem. So we decided to drop Festo and go for the SMC valves.
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
Unread 17-02-2008, 00:55
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
I agree, we went through 3 Festos, dump them, go with smc!!!
Faridodin "Fredi" Lajvardi KD7WKD
Unread 17-02-2008, 00:59
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
the kop solenoids don't work ever, order from festo directly.
R.C.
MadTown Robotics Team 1323
Unread 20-02-2008, 02:56
We've even found the metal festo's from the 2003 era to be crap too, if for no other reason than their excessively high pressure requirement to switch.
I'm totally for SMC, especially since they've stepped up in the past to give Canadian teams free cylinders in lieu of reasonable shipping time from Bimba.
Unread 20-02-2008, 03:08
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Going with the trend, we got fed up with our two festos about 2 hours before shipping and slapped on some of the SMCs and where in business
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 20-02-2008, 08:06
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
Start with the assumption that it is dead.
Pull a replacement valve and hook it up to the same way. If the replacement valve functions, the original valve is dead. If the replacement valve doesn't function, your wiring might be bad OR the replacement might be dead as well.
We had this situation arise earlier at the competition- the piston-fired arm wouldn't extend. I had the students go thru this sort of test- and the replacement work. Therefore replace and diagnose later.
Hope you found a solution before shipping!
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
festo solanoid mjgard Pneumatics 5 03-02-2008 11:26
Festo itay_ms Electrical 3 30-01-2007 09:08
Prob. With Windows 2k Staz Programming 2 15-01-2005 10:15
Analog Inputs prob. Bharat Nain Programming 2 07-02-2004 20:48
Programming Prob-Analog sensors!! LD8 Programming 3 03-02-2003 02:20
