Go to Post Coaxial swerve modules with a suspension and differential aren't normal. But on Winnovation they are. - Andrew Schreiber [more]
Unread 16-02-2008, 04:21
yay123 yay123 is offline
FRC #1657
yay123 is an unknown quantity at this point
Problems with output
We're using MPlab v 7.2 and sometimes we dont get outputs when the cable is conected to the controler and the computer.
We're using the new 2008 controler.
Unread 16-02-2008, 11:36
psy_wombats's Avatar
psy_wombats psy_wombats is offline
AKA: A. King
FRC #0467 (Duct Tape Bandits)
psy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura aboutpsy_wombats has a spectacular aura about
Re: Problems with output
By "sometimes," do you mean randomly, or is there a pattern to the behavior? What circumstances lead to the loss of output? And output from what to what? Computer to robot, or printouts from robot to computer?
Unread 16-02-2008, 12:58
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
You really haven't given enough information, but if I were to take a guess...
If you are using a USB to RS232 converter cable, a lot of teams have noticed they don't always work correctly and may be the problem you're experiencing.
Unread 16-02-2008, 17:11
FRC #1657
Hmm well, we got problem with the printouts from the robot to the computer, although, it happens only in one "FrcCode.mcw" file.
If we're trying to print something from the robot to the comp with other files, it works okay.. We know that the problem is the file, and we did include stdio..
hmm any suggestions?
sry for thr priveous bad explanation.
Unread 16-02-2008, 20:46
Racer26 Racer26 is offline
Its more than likely you're using kevin's 'serial ports' code, and you need to set the stdout serial port to port 1. I had to do this on my current code.
look through serial_ports.c i think it is for some direction.
Encoder Output Problems Mike Electrical 5 25-11-2005 21:43
Non Contact Magnetic Encoder with PWM Output Tom Bottiglieri Programming 3 09-10-2005 01:19
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Need help with animation output to VHS archiver 2001 3 24-06-2002 02:01
