Hey. We are trying to program autonimous with IR board.
here is our code: Code:
//**** Check the IR Sensor for a new command
sensorReading = PORTJ>>4; // Combined digital inputs 15-18
if (latch == 1)
if (sensorReading == 0)
latch = 0; // Take only the 1st reading to avoid being caught by a half & half state of the IR sensor
else if (sensorReading != 0)
latch = 1;
if (sensorReading == 8) IR_cmd = 1;
else if (sensorReading == 4) IR_cmd = 4;
else if (sensorReading == 2) IR_cmd = 2;
else if (sensorReading == 1) IR_cmd = 3;
printf("IR_cmd = %d\r\n", IR_cmd);
switch(IR_cmd)
case 0:
break;
case 1:
if (counter <= 50)
pwm01 = pwm02 = 255;
counter++;
else
counter = 0;
pwm01 = pwm02 = 127;
break;
case 2:
pwm01 = 200;
pwm02 = 55;
break;
case 3:
pwm01 = 55;
pwm02 = 200;
break;
case 4:
relay1_fwd = 1;
If we remove it, the motors never stop moving We want to have it configured so if button one is pressed, it will move forward for x seconds, and so on for the rest. another problem is that the relay will not fire. Any help will be appreciated. Thank you. |
Re: Programing IR board problem
If the relay is a single solenoid you might need to add:
relay1_rev = 0; If it's a double solenoid then depending on how it's wired it might possibly be: relay1_fwd = 0; relay1_rev = 1; How is counter initialized? Make sure you made counter either global or static and initialized the value to zero, otherwise, counter will be zero everytime this gets executed and it will go on forever. Resetting counter to zero will just continue the loop endlessly. Last edited by Mark McLeod : 16-02-2008 at 17:28. |
The variable is static, and initialized to zero.
static int counter = 0; |
Well, the only thing I see (if the "command = 0" line is removed to prevent the endless looping) is that IR command 1 would not work properly if you ever pressed it a second time. That could be fixed a number of ways, e.g., use a toggle to reset counter=0 when the button is pushed a second time.
so i would do this?
case 1:
counter = 0;
if (counter <= 50)
counter++;
else
break;
Maybe something, such as,
if (latch == 1)
latch = 1;
if (IR_cmd == 0)
counter = 0; // To initialize counter whenever cmd 1 finishes executing
switch(IR_cmd)
case 0:
break;
case 1:
if (counter <= 50)
counter++;
else
IR_cmd = 0; // So cmd 1 won't try to repeat itself
break;
case 2:
pwm01 = 200;
pwm02 = 55;
break;
case 3:
pwm01 = 55;
pwm02 = 200;
break;
case 4:
relay1_fwd = 1;
| IR board problem | AmitCarmeli | Electrical | 3 | 09-02-2008 18:53 |
| Another IR Board Problem | C222 | Electrical | 2 | 13-01-2008 17:36 |
| Do you have a problem with the IR Board? | DonRotolo | Control System | 5 | 07-01-2008 23:57 |
| Lights in Joystick board or control board | rcubes85 | Control System | 15 | 26-02-2005 23:40 |
| Perf Board = BS2-IC Carrier Board? | indieFan | Electrical | 2 | 16-09-2004 08:28 |
