Go to Post There is no MILSPEC standard for pool noodles. - Rick TYler [more]
Unread 20-02-2006, 22:47
P1h3r1e3d13's Avatar
P1h3r1e3d13 P1h3r1e3d13 is offline
Unregistered User
FRC #0295
P1h3r1e3d13 is an unknown quantity at this point
Question "RC Hardware" light: +5V failure
The "RC Hardware" LED on our RC is solid "yellow" (it really looks like orange), indicating +5V low. We removed all our digital I/Os, made sure the pins were clean, then put our voltmeter to it and found out we had no voltage at all on the pins. We figure whatever internal voltage regulator the board has must be blown/fried/dead/[pick your own euphemism]. No magic smoke, but one person thinks the RC might be running a little hot.
Any ideas?
Unread 21-02-2006, 01:01
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
Re: "RC Hardware" light: +5V failure
Any ideas?
Check your backup battery
-Mike
Unread 21-02-2006, 01:03
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Unless you removed all the Digital I/Os at once, you may have a short. We had this issue becuase our GTS was touching the transmission (sharp solder point went trhough electrical tape). Other than that....just check the basics and stuff for issues.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 21-02-2006, 03:33
Unregistered User
FRC #0295
Backup battery is fine (7.78 V no load) and we did remove all the digital I/Os at once. We were hoping it was a short, but testing the pins directly showed no voltage between the +5V and GND pins.
Unread 21-02-2006, 07:28
The internal +5 volt regulator is self protected for over current and over temp. Usually letting it cool for fifteen to thirty minites will heal that problem. Then you must find the short on the +5 volt rail. Start by removing all inputs and outputs and then put them back one at a time while monitoring the +5. All will be revealed.
Unread 16-02-2008, 18:25
bixbyrobotics1 bixbyrobotics1 is offline
Whiteway
AKA: Alex Whiteway
FRC #2424
bixbyrobotics1 is an unknown quantity at this point
Send a message via AIM to bixbyrobotics1
We are having the same problem with our RC, but even after a week with nothing connected to the RC we still get the error, and we desperately need the 5v!
Unread 16-02-2008, 18:58
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Omg we just had the same problem yesterday. After reading the manual I found out that there had to be a short somewhere in the wiring (thats what the light means). So a mentor and I pulled all the PWM cables out to try to find the short (if the light goes out the short is on that cable) but the cables were all find so I checked all of the male connections on the RC and one of the Analog outputs had a small metal shaving across it thus causing the short.
The light has nothing to do with the backup battery, if the backup batery was the issue then the light would light up on the OI. My suggestion to you would be turn your robot on and disable it. Then unplug each wire one by one. If the light goes off the problem is on the line. If they are not your problem then keep the robot on and disabled, get a toothpick or other thin object and run it between each pwm outputs/inputs. This should dislodge any thing that will short the outputs/inputs out.
-Dustin Benedict
Unread 16-02-2008, 19:02
Gdeaver Gdeaver is offline
FRC #1640
We had the same problem yesterday. It was a short on a switch.
Unread 18-02-2008, 07:45
Bix,
Please examine the pins on your RC very closely and I bet you will find two that are touching. May have been damaged while someone was holding it.
Unread 18-02-2008, 08:01
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
You may also have managed to get chips in somewhere more... vulnerable. Two years ago in our 2006 robot, someone was drilling a hole right above our RC in our shooter's mounting bracket. The robot went to the field before anyone got a chance to get the vacuum... and during the course of the match a small aluminum chip managed to work its way underneath one of the LEDs in the top of the RC and into the protective plastic box that covers the top of the circuit board.
We later found out that the chip of aluminum soldered itself on with the initial arc when it hit the V+ and GND pins.
Moral of the story... always cover the RC and have a small vacuum cleaner handy!
-q
p.s. Since it's already broken as it sits, you may choose to void the warranty (which does not apply in this case anyways) on your controller and remove the four screws on the bottom that hold the top plastic cover on to expose the middle part of the PC board. There, look for the National semiconductor regulator (big power mosfet looking thing with heatsink) and see if your chip is there. If not, look around and i'm sure you'll find a short somewhere. Let us know here if you have further problems.
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 18-02-2008, 17:48
Unregistered User
FRC #0295
So I'm sure you all need another anecdote, but two years ago, we were smart enough to drill/file/saw our aluminum frame with our electronics installed. ("It was just a little repair.")
We let the magic smoke out of three Victors and lost our +5V line (see my posts above). We found little metal shavings in everything, of course. We were able to replace the transistors in the Victors for a tiny fraction of the price of a new one, and if I remember, we got our RC ultrasonically cleaned and it worked. We also returned it under warranty later for some other reason.
But after all that, you can be sure we always removed our electronics or covered them in plastic before making metal shavings. I advise everyone to do the same.
Unread 18-02-2008, 18:08
swalker92 swalker92 is offline
AKA: Sam Walker
FRC #2424
Team Role: Driver
swalker92 is an unknown quantity at this point
my advice is hook up an air sprayer to a compressor and unhook everything and just blow the heck out of it. we had a piece of metal so small you couldnt see it shorting ours
Unread 19-02-2008, 07:32
I know a lot of people recommend using high pressure air to blow out debris, but I find that forces debris into areas you don't want it to be. Cover electronics and if needed use a vacuum to remove visible particles. The Victors are open on the top and closed on the bottom, so debris goes in but doesn't easily come back out.
Unread 19-02-2008, 11:05
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
I have a great one for you. Same problem only the aluminum chip was UNDERNEATH the analog header pins. It took me a few hours to find the problem. After replacing the 5volt reg and performing several tests I realized that there is a small space between the bottom of the header pins and the PCB. When the RC was held up to a light It was obvious that the there was something underneath the pins. The trick was getting it out. I ended up fishing it out with a stiff piece of wire.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Light fades out? Mike Programming 13 17-01-2006 23:13
How many users does it take to change a Light Bulb? Matt Attallah Chit-Chat 4 04-09-2004 20:59
Please...no more steenkin' light! Andrew General Forum 37 17-04-2003 23:06
Important info about light Jay Lundy Technical Discussion 10 12-04-2002 11:37
How many posters does it take to change a lightbulb? Brandon Martus Chit-Chat 7 22-02-2002 19:48
