Go to Post I feel there really is only one team, and the name of that team is FIRST. - [more]
Unread 16-02-2008, 20:58
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Alternative "Fix" for IR Sensor to Team Update 10
Update 10 suggests putting a switch in series with the power of the IR sensor board. Unfortunately this is a hassle in that you have to remember the process of turning the robot on, then turning the IR board on, and the reverse order for shutting everything down.
Instead of using that we decided to hook it up to a Spike Relay. Hook the 12V and GND up as normal and then hook the power of the IR sensor to M+ (or M-, or both if you're using two IR sensors). Then the ground of the IR sensors goes to ground on a breaker panel. Using this you must turn on the IR sensor using the program as follows in the chart below.
So if you connect the IR sensor power to M+ you would set the relay output fwd to 1 in order to power the board, 0 to shut it off. Remember though that your board will only work when the robot is enabled now.
INPUT                         OUTPUTS
Fwd(Wht)    Rev(Red)    M+    M-    Indicator    Solenoid Function
    0            0      GND GND      Orange      Both Solenoids OFF (default)
    1            0      +12v GND     Green       Solenoid connected to M+ is ON
    0            1      GND +12v     Red         Solenoid connected to M- is ON
    1            1      +12v +12v    Off         Both Solenoids ON
Hope that helps!
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 16-02-2008, 21:08
iambujo iambujo is offline
FRC #2729 (Storm)
iambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to alliambujo is a name known to all
Re: Alternative "Fix" for IR Sensor to Team Update 10
Thanks for the suggestion.
For those of us which it is too late since ours is already fried, in the Team Update 10 it is stated:
"If you have reason to believe that your PIC code has been corrupted, and you have the capability program PICs, you can use the code that Mr. Grieb has graciously provided."
Has anyone found the code posted anywhere?! Even if a team is able to flash the PIC, that is not too helpful unless the code actually becomes available.
Thanks
Unread 16-02-2008, 21:12
3dude_2231's Avatar
3dude_2231 3dude_2231 is offline
no one messes with a Thingy =|
AKA: Menscher,Ran Menscher =]
FRC #2231 (Onyxtronix)
3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough3dude_2231 is a jewel in the rough
Send a message via MSN to 3dude_2231
we had our IR board not working,
indeed today I sent an Email to Mr. Greib (thanks again =] ),
in 30mins we had the IR working again.
I suggest you contact him yourself, if you a reason to believe it's a program with
the onboard PIC. (his mail is found in IFIrobotics.com)
Ran
EDIT:
please refer to this thread
Redefining the word "Rookie". (for 2 years now..)
Israeli Off Season Games: WINNERS!
check out this cool project I'm into..
Unread 16-02-2008, 21:26
Running Riot
AKA: Patrick Cloke
Thanks
No I have been unable to find the code. :-\
Ran
I emailed him and he hasn't gotten back to me. Is it possible for you guys to post the code? Thanks.
FIRSTsearch
Unread 16-02-2008, 21:29
3dude_2231's Avatar
I have posted it here
Unread 16-02-2008, 21:32
Running Riot
AKA: Patrick Cloke
Thanks a lot.
FIRSTsearch
Unread 16-02-2008, 22:04
FRC #2729 (Storm)
Thank You!!!
"TEAM in a BOX" : Shipping Update!! OZ_341 General Forum 1 02-10-2005 21:32
Help us Update "Team in a Box" OZ_341 General Forum 20 06-09-2005 01:26
Team Update #19 - "Double Play" George1902 General Forum 31 11-04-2005 01:17
Team 617's Suggestions For Things To Do In Between "Fix-It" Window & Your Regional The Broox Chit-Chat 14 02-03-2005 20:17
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
